KitchenAid KCM511OB 10-Cup Coffee Maker Logo
Posted on Apr 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I turn the beeping off on my Kitchenaid Coffee Maker when it's brewing?
Anonymous
Level 2:
  • Expert 145 Answers
  • Posted on Jul 08, 2009
Anonymous
Expert
Level 2:
Answers
145
Questions
0
Helped
154258
Points
404
There is no programming function that allows the beeping to be turned off on a Kitchenaid Coffee Maker.
Beeping sound, won't brew
Our Hassle-Free Replacement Warranty guarantees that if your PRO LINE™ countertop appliance fails in
the first two years, KitchenAid will replace it free of charge. We will:
  • Deliver a replacement to your door
  • Arrange the return of the failed appliance
  • Guarantee the new appliance for two years
    For more information or complete warranty details on KitchenAid® PRO LINE™ countertop
    appliances, please call Customer Service at 1-800-541-6390 or click here.
    spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif Product Literature spacer.gif Additional Resources
    1helpful
    How do I run the clean cycle?
    I assume you mean descaling the coffee maker when the Clean indicator flashes after a brewing cycle. You can use a packaged descaling product or white vinegar. For the packaged descaling agent, follow the package directions for the ratio of product and water. If you are using vinegar, fill the carafe with a 50:50 mixture of water and vinegar.
    Remove the water filter and remove any coffee and coffee filter from the brew basket. Make sure the unit is plugged in and turned on. Pour the descaling mix from the carafe into the water tank and then place the carafe in the coffee maker. You have 10 seconds to program the cleaning mode or the unit will return to the standby mode. The next step depends on the type of carafe. For a machine with the glass carafe, press Mode 6 times. Otherwise for a unit with the thermal carafe, press Mode 5 times. The Clean indicator will blink. Press Program/Set followed by the + or - button to select Clean On. Press and hold Program/Set until you hear the beep. Press Brew and wait for the cycle to complete (the Clean indicator will go off). Then do two brewing cycles with water but no coffee or coffee filter. Discard the fluid from the coffee maker from all three cycles. Wash the brew basket and then reinstall the water filter.
    If you notice an odd taste to the coffee when you next brew some, do at least one more rinse with water (remove the water filter and coffee grounds/filter).
    KitchenAid manuals are available from their site: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . The direct link to the manual for the Kitchenaid KCM223OB is http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10321647.pdf . See page 13 for the directions.
    I hope this helps.
    I have a Kenmore Elite Coffee Maker, I press brew, the light flashes and then it beeps but does not brew.
    gotta have the correct time set, also check auto brew timer. Coffee pots usually beep when they are done brewing and then when it's turning off, usually after a hour. Play around with timer (hrs. and min.)
    3helpful
    2answers
    Need To Turn Off Beeping After Coffee Brews
    on my 12 cup kitchenaid coffee maker, i can press and hold the Auto button to enable/disable the alarm
    How to clean the kitchenaid java express coffee maker
    The Coffee Maker can be descaled using
    a packaged descaling agent or vinegar.
    Always mix the descaling solution using
    cool water.
    • When using a descaling agent, follow
    the directions on the package for the
    recommended amounts of descaling
    agent and water to use.
    • When using vinegar, fill the carafe with
    a solution consisting of 1⁄2 vinegar and
    1⁄2 water.
    Descaling Steps:
    1. Before descaling, always remove the
    water filter (see “Installing the Ion-
    Exchange Water Filter” on page 7) and
    make sure the brew basket contains
    no coffee or coffee filters.
    2. Run the Coffee Maker through a
    complete brewing cycle using a full
    carafe of the descaling solution.
    3. If the cleaning needed indicator lights
    after the brewing cycle is complete,
    repeat Step 2 using fresh descaling
    solution. Keep repeating Step 2 until
    the cleaning needed indicator no
    longer lights after brewing.
    4. Rinse the Coffee Maker by running
    it through two brewing cycles using a
    full carafe of fresh, cool water
    each time.
    5. Wash the brew basket in hot, soapy
    water and rinse with hot water. This
    part can also be washed in the upper
    rack of the dishwasher.
    6. Reinstall or replace the water filter.
    Replace the filter every three months
    under normal usage, or more often
    with heavy use.
    KitchenAid 10 cup coffee maker Model # KCM511ER-1 Ser# WGT4409334 Pushed the Brew button after a Min. or two it beeped and Replaced the time with "Err2". the coffe maker did not warm up or...
    An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears.
    If the code does reappear, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
    Their toll-free telephone number is 1-800-541-6390.
    7helpful
    3answers
    Turn off beeping alarm when the coffee maker is done brewing
    you can't ,its up in the top behind the controls.
    you have to take the pot totally apart.
    only a trained tech should attempt this.
    4helpful
    2answers
    Coffee maker beeping
    Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
    2answers
    go to this link armed with your model number for the manual(they help you to find this on the site if you have trouble). http://www.kitchenaid.com/custserv/service.jsp If you get no luck from that then please ask again. Hope this helps :)
    Top KitchenAid Coffee Makers & Espresso Machines Experts
    ZJ Limited
    ZJ Limited
    Paul Carew
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
