I need the calculator to show 2 decimal places
Input the following and try:
For normal, just take calculator out of FIX so just DEG shows.
Couldn't find you a YouTube video, so text will have to do.
[email protected]
SOURCE: need to program to fifth decimal place
Your BA II PLUS stores numeric values internally to an accuracy of 13 digits. However, the numbers it displays depends on the number of decimal places to which you have it set (choice of 0–9 or floating decimal). To set the number of decimal places displayed to three: hit [2ND][FORMAT][5][ENTER]This setting also continues indefinitely (even though the calculator is turned off and on) until it is changed.
SOURCE: decimals
This is an easy one and happens often. Simply depress the orange "f" key and then select how many decimal points you want on the numeric keys. For example, for two decimal places you would push "f" 2. I usually keep mine on 3, but you can take it from here.
SOURCE: I have the Canon LS-100TS
Try switching between business and tax mode, the little toggle switch at the top of the calculator.
If that doesn't work repost.
Hope that helps
