Question about Canon Rebel XT / EOS 350D Digital Camera
Canon rebel eos xt freezes up
Our camera has been freezing up.  we sent it away and they said nothing was wrong . it had also flashed err 99 (apparently after a little rest it started up again). we then bought a new card and new battery.  it worked for awhile and then quit on and off and then finally just gave up completely.
  • Anonymous May 10, 2009
    I have the same problem happen to me a few times already. I'm sorry I can't answer your question, but I did find this. I'm not using a Professional 80x-speed Lexar CF card, but on Wiki it is stated as a potential problem for freezes. My rebel is a few years old, so maybe it's wear and tear causing my problem. I do hope you find an answer to yours. Oh here is the link for wiki where I found the info about the CF card.
    http://en.wikipedia.org/wiki/Canon_EOS_3...
6ya staff
SOURCE:
Anonymous
SOURCE: Error 99 only when flash pops up
We ended up sending the camera in to Canon. $200 unless they find something more wrong. Luckily we have my Nikon D80 still. I will say that Canon replied via e-mail fairly quickly and one paid, said 7-10 business days for the repair.
Posted on Dec 09, 2007
Anonymous
  • 216 Answers
SOURCE: Canon Rebel Xt EOS Err 99
Error 99 is a "catch all" error that has several causes. It could be that your battery is not fully charged, especially if it is a generic, non-Canon battery. Charge for at least over night even if the charger says it's full. If that's not the cause, switches inside the camera will have to be cleaned by a repair shop.
Posted on Nov 27, 2008
Leons Jose
  • 8 Answers
SOURCE: err 99 on canon rebel xt 350 d
The Err 99 problem occurs due to dirty contacts between the body and the lens. I recommend cleaning the contacts. You can then turn Off the camera and then remove and reinstall the batteries to reset the camera to get the problem fixed.
Posted on Jan 15, 2009
mcomijohns
Mike Johnson
  • 477 Answers
SOURCE: Canon EOS Xt displays Err 99 how do I fix it.
change the lens or try cleaning the connector tabs with a eraser.
Posted on Jun 27, 2009
Ty Price
  • 11967 Answers
SOURCE: Error 99 in Canon EOS Rebel XS 1000d
Have you been to the support section of Canon's website to find out what "error 99" means?
Posted on Aug 21, 2009
I have a Canon EOS Rebel XT purchased in 2006. I keep seeing the message error 99 repeated over and over Thank you Kim Atkins
If I remember correctly, this message is caused by a loss of communication between the camera body and the lens.
It could be dirt related, or even wear related. Some are not !
There are quite a few discussions about this on the net.
I suggest reading some of the entries.
Jun 08, 2011 | Canon EOS Rebel XT Digital Camera
Changing that setting was aparently a BAD idea!
Hello: Try updating the firmware for the camers and software. Go to canon and download the firmware to a flash drive and connect your camera and install the latest firmware from canon.
Oct 20, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Jun 26, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon rebel xt eos
Error 99 means lens communication error.
Try to clean the contacts on both sides.
and re-install lens
Jun 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Error 99 message keeps popping up
err 99 is moisture or dew inside the camera.
May 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 99 on canon rebel xt 350 d
Jan 15, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Nov 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
I know what you two are talking about. I ordered a Canon EOS 300d from a site called "Keh" and I had never used one before... so I get it in the mail on time. The camera works fine for a few minutes then I get an "error 99" and can't do jack with the camera. I researched online and even called keh ... I read and heard that it has to do with the lens... so I sen't the camera back and got my money.
Nov 26, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
810 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
