I don't know what to do it goes to black screen and then says starting automatic repair after a long pause it gives a frown face and says computer has crashed and will restart but it doesn't and it won't bring up anything not even the restore. Don't know what to do it is only 6 months old won't read the restore Cd's eiher.
SOURCE: hp pavilion dv9000 cd player quit working
Sounds like a bad cdrom... if the BIOS / CMOS doesn't pick it up during post, need to make sure it is seated good. Otherwise, just replace it.
SOURCE: My Hp Pavilion dv4000 screen stays blank
have you got a bootable cd or recovery cd , boot from it and do a fresh installation, i think your windows has got corrupt
run the repair from the install disk.
SOURCE: on startup i have multiple screens and then the computer hangs
Reinstall latest release from Microsoft.. it should solve the problem
SOURCE: When I turn on my
Well I had this problem and fixed it for good finally. Things you will need.
3 pennies
solider
heat gun
pliers
foil
First you remove the motherboard. Which you can find on youtube. Then remove heatsink with 4 screws. And 2 screw with the fan.
Next take the heat gun and heat up the aluminum block that isattached to the heatsink. It is the only thing that looks like a silver square. Heat it up and use the plier to pull it off.
Next take the pennies and clean them real well. I use the pliers to scratch them up real good. Put one on your range and take alittle solder and put it on top. Turn the range on high and wait for the solder to melt. When it does put the next penny then more solder and then the third penny. Now take a the pliers and push down on the top penny and turn off the range let it cool before you remove the pliers. Now you have a stack of pennies solder together.
Now where you removed the metal block, Turn it over to the side with the copper pipe. heat it upwith the heat gun and fill in the gap between the pipe and the plate of copper.
Once that is done flip it over. Now put alittle solder on the spot where you plulled off the block. Heat it up with the heat gun again and put the stack of pennies on it. Make sure it centered. Let it cool and the heat sink is done.
Now go to the motherboard the second biggest chip there is the graphics chip. Make a foil square cut out a hole big enough for that chip. The chip should have a red type of glue around the corners. Put the heat gun 1 inch away for about15 secs then let cool. Once cool do it one more time for 15 secs.
After that you should be ok put the heat sink and motherboard in the case with 1 stick of ram and plug in the screen. Plug in the ac and try it out.
Mine has been working for 10 hours straight.
