SOURCE: Okidata ML320 feeding blank sheets
Which IBM driver are you using ? try using a IBM proprinter driver.
Hope this helps.
Dezzi
SOURCE: Paper does not feed completely properly.
Hi all
The usual problem with this combo is the 1st paper feed roller,this becomes "glazed" with the additives in modern papers.
To gain access remove the power supply remove 1 screw holding its retainer in position and remove it.
Remove the white gear on the end of the feed roller shaft (it is fiddly) and then withdraw the whole feed roller assembly.Clean the roller with meths or alcohol making sure that you get rid of all the rubbish and that roller feels like rubber again.
Reassemble and away you go.
Cheers Davwiz
SOURCE: Printer sends out extra page everytime I print
either your paper size settings need to be adjusted in the software, or your setup has included a seperator page.
