hi Robert.
i can not find a manual for this watch,but if you go to this link it should show you step by step on how to set it up.
its not showing your model number so not sure how good it will be to you.
if another window opens on the page just close the popup window down.
or try this. How do you set an armitron pro sport watch?
Press the "Mode" button repeatedly until the time display appears on the watch. Hold the "Mode" button until you see the alarm display appear, then release the button. Hold the "Mode" button a second time to enter the time-setting mode.
I found instructions here. http://www.livestrong.com/article/306545-armitron-black-red-womens-sport-watch-instructions/ Although, I can't figure out how to turn off the alarm.
here's a simple instructions of setting your watch
Watch setup instructions for the Armitron Instalite All-Sport :
Mode B / \ C Date ' ' Light A \ / D Alarm
_____________________________________
Set time time / date
Press and hold B (Mode) untill alarm hours flash Press D (Alarm) to advance these
Press B (Mode) again, seconds will flash, press D (Alarm) to advance these
Press C (Date), minutes flash, press D to advance these
Press C again, hours flash, press D to advance these
Press C again, month flashes, press D to advance these
Press C again, Date flashes, press D to advance these
Press C again, Date flashes, press D to advance...... [suggestion from Chikita]]
Activating/Deactivating Hourly Chime
1. From "Normal Time Mode", press and hold "D" (Alarm) and at the same time press "C" (Date) once. Hourly chime symbol, ( a house shape) appears in "chime" windows to indicate the hourly chime will beep every hour.
Activatin/Deactivating Alarm
2. With "D" (Alarm) still pressed, press "C" (Date) again. Alarm symbol ( a clock shape with waves above it) appears in the upper right to indicate the 24 hour alarm is now activated.
[I assume this "toggles" between off and on states, so performing it again should turn off the alarm]
i hope this will help you.
I will be glad to help you with your concern regarding your Armitron
Wristwatch, what exactly would you be experiencing? cause I only put
info on how to set time and date on the Watch.
Please see below steps:
Your Armitron Watch will have Four
Button
on the side of the watches rim.
Button on the upper
Left is MODE.
Button on the lower
Left is LIGHT.
Button on the upper
right is DATE.
Button on the lower
right is Alarm.
See
Steps below: *Setting the time*
Press and Hold down the Mode Button
til the Hours flash
Then push Alarm Button to set the Hours
Press and Hold down
the Date Button till the
Minutes
flash, then push Alarm Button to
set the minutes
After setting the minutes on your
watch, Press Date
till you get the month flashing push Alarm to set the month
Press the Date
again till the Date flashes, then push
Alarm to set date
Press the Date again
till the Date on your watch
flashes, then push Alarm to set
the date
After setting everything push the Mode Button again
just once to set everything or finalize your settings on the watch.
I
hope that this will be of help regarding your query on how to set the
time on your Armitron watch, I
also included the setting of the time and
date just for further details.
Here's how you set the 40/6623 M175 for anything. I figured it all out with help from here :). Okay so want to set the alarm? Press MODE once. Then hold it. And use the DATE and ALARM buttons to set the alarm. Press MODE twice and you're done. To set time do the step before this and press MODE once. Use the DATE and ALARM button to set the time. As for the 24 hr deal what you do is hold ALARM and press MODE or hold MODE and press DATE. To turn alarm on/off hold ALARM button and then press the DATE button. To set the date go to time set mode and keep cycling between the hours and mins until you get to the date :). That's all you gotta do :D. I know many of you need the instructions so here it is!!
You can get instructions from the Amitron web site. Copy "www.armitron.com/watch_instructions.asp" into your search engine and you will see a list of illustrations of watches and associated instructions.
Choose the one that looks like yours and download the PDF file
Armitron All-Sport Watch Instructions
By Brian Walker
eHow Contributor
9 Found This Helpful
The Armitron All-Sport is a unisex style of watch made by Armitron that features a digital readout and four buttons around the outer dial for adjusting various aspects of the watch. It can set alarms, keeps the time as well as the date, and has a built-in backlight. Accessing and adjusting these various settings is a fairly simple process.
To enter the date and time setting mode, press and hold the "mode" button, located on the top-left of the watch. Continue holding this button until the display begins to flash. This first display is the alarm setting, should you choose to set an alarm to go off. If you'd like to set the alarm, use the "alarm" button on the bottom-right of the watch to advance the hours to the desired one. Then press the mode button again; this will cycle through the minutes and seconds of the alarm to allow you to set those as well. Once you have set the alarm, you can press the "date" button at the top-right of the watch to proceed to the regular time setting. These numbers, which will now be flashing, also are adjusted by pressing the alarm button to change them. Pressing the date button again will now cycle through the hours, minutes, seconds and the date. As you continue to press the date button, the All-Sport will continuously cycle through these options; don't worry if you forget to set one, you can simply press the date button a few times until you get back to the setting you need to change. Once the alarm, time and date have all been set, you can press the mode button one more time to exit to the normal watch mode that will display the date and time.
Using Chime and Alarm
The Armitron All-Sport features both an alarm and an hourly chime. The alarm function will cause the watch to continuously beep at the selected time until you turn it off by pressing a button. The chime will cause the watch to beep once every hour. You can turn both these features on and off by pressing and holding the alarm button and while holding it pressing the date button. The first time you do this, the chime will turn on and a small house symbol will be displayed on the watch face. Performing this button-pressing sequence again will turn on the alarm, which in turn displays a small clock icon on the watch face. Each successive pressing of this button sequence will alternate between the chime and the alarm, turning them either on or off.
Backlight
The All-Sport also features a built-in backlight to help you view the watch in dark conditions. This light can be activated by pressing the "light" button on the bottom-left of the watch. Pressing this button is the only way to activate the light, and doing so will only cause the watch to illuminate for a few seconds at a time.
