The choice between the VLSI (Very Large Scale Integration) domain and the IT (Information Technology) sector depends on individual interests, career goals, and skills. Both fields offer unique opportunities and challenges.
VLSI Domain:
Pros:
Involves designing and building integrated circuits, offering a specialized and in-depth focus.
High demand for VLSI engineers in industries like electronics, telecommunications, and semiconductor manufacturing.
Opportunities for innovation in emerging technologies like IoT, AI, and smart devices.
Cons:
Specialized nature might limit job options compared to broader IT roles.
Continuous need for updating skills due to rapid advancements in technology.
IT Sector:
Pros:
Diverse career paths, including software development, system administration, cybersecurity, data analysis, and more.
Broader job market and opportunities to work in various industries.
Flexibility to transition between roles and adapt to evolving technologies.
Cons:
Intense competition in certain IT roles.
Jobs may not be as specialized, and depth of expertise might be more challenging to achieve in specific areas.
Ultimately, the "better" choice depends on your interests, skills, and career goals. If you are passionate about designing integrated circuits and working on cutting-edge technologies, VLSI could be a great fit. If you prefer a broader scope with diverse career paths, the IT sector might be more suitable. Consider your strengths, preferences, and where you see yourself thriving in the long term.
I'm not sure what you mean; if you want to make a chip, you need to learn about the processes (CMOS, VLSI, etc.; see local libraries, semiconductor magazines online, and even Intel's investor materials among others) and make about a billion in process licenses and investment to get going. Vendors to those businesses include Varian, AMX, SEMI.org...you can look into their business information. PCBs (the printed circuit boards) are considerably easier to make, but chip packaging has still more conductive traces (lines) as an intermediary that has been a hurdle for new chipmakers. There's an IPI and IPC separate from the language ones just to help one sort that one out!
About 3000 times more easily than that, you could study electronic engineering and VLSI to get into the industry. Or, 2020 times easier than that, just learn Xilinx's tool for programming their programmable chips and get a lot of control over what the lines do. Electronics vendors like Avnet sometimes hire technicians like that last one. Then, if you end up getting a few MSEE or physics degrees you can lean towards your own fab.
These are embedded into the VLSI board and is embedded. So it is also the microprocessor to the phone. checck to see and clean the board and the plated through holes that connect both sides of the board. it is possible that some connecions have opened on the board which means your board is faulty.
you're not quite clear as to what your problem is. if your unit is a european model the easiest way is to use an external NTSC to PAL converter which would enable you to view phil programs on your PAL TV. Prce range from P4000.00 to P150,000.00. Or you can have a competent technician modify your TV hardware which would depend on the availability of part. In the past, during the advent of OFWs going to the middle east, you would spend like P2500.00 for conversion, parts and labor. Parts may still be available in raon, mnla. It is not feasible nowadays, though, as of course you already would probably know that you can buy surplus tvs for as low as P2000.00 for the 29" types in cubao or pier. Used LCD tvs or montors are also available cheap, from P1500.00 to P3000.00. If your unit is a PAL/NTSC selectable, then you're probably better off using it as a monitor as parts for the circuitry of the color system select may not be available since they are usually part of a VLSI IC.
if the track numbers are displayed and counting then we can assume the cd is playing. and the sound/audio decoder is defective. it is usually a large integrated chip.(VLSI).
Dear friend I don't know C++ well but I just can suggest you to check this website:
http://www.codeproject.com/
I think you can find your answer there easily by a simple search.
I hope it could help.
Good luck
