Lexmark x7675 all-in-one printer won't accept paper type. I am trying to print onto an 8-1/2 x 11 iron-on t-shirt transfer sheet, but it won't let me. It also won't let me print onto card stock-weight business cards. However, it will let me do this at other times with the same types of paper. It is just depends on what day it is as to whether or not I can do it or not. Sometimes it is no problem, and other times it will say ''unsupported paper type''. I have tried to change the default on the paper type, but it still does not help. This is very frustrating and holding up my work.
SOURCE: Lexmark Opra M410 Laser
Your printer has a separation pad that is worn out and needs to be replaced. This pad prevents the printer from feeding multiple pages. It is located in the inside front of the paper tray Assembly.
SOURCE: We have a Lexmark X5250
I have to select -print first then when I get the "load paper" message, turn the printer off . wate a few seconds then turn it back on. I will then feed the paper and print. I may end up replacint the printer.
SOURCE: iron on transfers lexmark x1290
In your printer driver, select the highest dpi setting and the correct paper setting for your type of printer:
Iron-ons are very waxy and the ink may not adhere if not put on thickly. Bellow are some suggested printer settings. For the best results check your printer manual or with your printer's manufacture.
CANON: T-shirt transfers.
EPSON: High quality glossy paper or special coated paper, depending on the model.
HEWLETT-PACKARD: High quality glossy paper.
Lexmark: T-shirt transfers.
IMPORTANT: Then set the paper thickness lever on your printer for standard paper. You want the ink nozzles very close to the page.
SOURCE: printer will not pick up card stock - aaaghh!
Try cleaning the rubber roller tha picks up the paper with some alcohol and a rag.
SOURCE: Printing on business card stock
goto avery website and download designpro for free it has all the templates for avery stationary
1. Browse to
Start -> Run... and type in "NET STOP SPOOLER" (this will stop the
print spooler service)
2. Browse to your
windows\system32\spool\PRINTERS\ folder. You should see files there ending in
.SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to
Start -> Run... and type in "NET START SPOOLER" (this will restart
the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside for any debris.
3. If you're willing and physically able, you may also
turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the
table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris
that could cause this error or problem.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet
to reset it.
8. When the printer turns on, reinsert the cartridges and
load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge
first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge.
Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
