I have a belkin N wireless router and have moved to an apt that i am now considering buying comcast services. If i need a modem for services, which one is compatible with me router? Or do I need to buy a new router or change services?
When you speak to Comcast you should see if they are providing you with a wireless modem/router that will be everything you need.
If so, you will not need the Belkin router as Comcast will supply you with the hardware you need. If they only give you a modem, your Belken wireless router should work fine with the Comcast modem.
Hope that helps!
SOURCE: Belkin N1 Router connection drops when phone rings
You may have a phone line connected from the modem to a wall outlet. Count the number of cables coming out of your modem - you should have only three: the power cable (connects to the wall), Cat 5 (also connects to the wall), and ethernet (running from the modem to the router).
SOURCE: Belkin F5D77230-4 - connecting to modem
k ur modem is usb one either u need to change the modem has ether net or get a convertor like usb to ethernet better contact isp and change the modem rate me solved if its help full
SOURCE: Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to 192.168.0.1
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
SOURCE: Belkin N1 wireless router drops offline
The connectivity issue with your Belkin router could be due to a couple of different items. Your ISP might even be able to shed a little light on the subject.
I would also go to Belkin's website, and go to the support area by clicking on Support Center in the left pane of the sight. You can then search for your product number. With the results that you receive, you will be able to see what version of firmware they have, which is like doing a software upgrade on your computer. There should also be a step by step process on the website for you to install the firmware. I would do it from a desktop that is connected physically to the router.
Please let me know if you would like further assistance with this matter. Thank you.
SOURCE: Belkin Wireless N router/Embarq 660 modem/No internet
THE PROBLEM IS THAT THE BELKIN RTR AND THE 660 HAVE THE SAME IP ADDRESS THE QUICKEST FIX IS TO RENAME THE LAN IP ADDRESS OF THE BELKIN RTR
