2004 Land Rover FreeLander Logo
Posted on Mar 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Freelander diesel is losing water but not affecting performance.no sign of leak,any ideas?
  • Jani P Jani
    Jani P Jani Mar 07, 2019
    Hi, did you manage to find the problem? Coz I seem to have a similar problem with my Evoque SD4. Had an accident, my intercooler and radiator were replaced, now the problem is i keep loosing coolant, Land rover did a pressure test but the guage did not drop at all, no leaks, no white smoke, no engine management light, no bubbles in the coolant tank, performance is good.
Anonymous
Level 2:
  • Expert 158 Answers
  • Posted on Mar 31, 2009
Anonymous
Expert
Level 2:
Answers
158
Questions
0
Helped
58410
Points
493
Is there any water coming out the exhaust when driving under load if so the head or head gasket has gorn Lindz
2answers
I have a 1998 Freelander 3dr Tdi (L-series Diesel) It just started to idle high (just above 1000rpm) and sometimes it would shoot up to between 3000-4000 rpm when ingaging the clutch (when coming to a...
Check for a possible leaking vacuum system, maybe the vacuum booster is leaking, that would explain the idle being affected by stepping on the brake pedal.
2003 Dodge Ram 2500 Diesel. October I noticed
Replace heater hoses, Sometimes the inner lining of hose forms pockets that plugs flow of fluid.
Loss of torque
your timing belts are probably loose or worn and the timing is slightly off which results in diminished power. check out www.rockboundrovers.com for freelander needs.
Freelander loosing/using a little water & running slightly hotter
Might be worth changing water expansion tank cap these can lose water under pressure
1helpful
Rover 45 problem with water leaking
Hi sorry if this response is a little late,,, i aint been on for a while,,, the thermostat could cause the heat problem but if you loosing coolant it has to go somewhere,,, check for dripping anywhere under the car and around the cylinder head,, the head gasket can leak 1 of 2 ways out of the head/into the head but lets rule that out for now as now over heating,, if you have had the waterpump replaced go for the thermostat it should cure the problem ,
Hope this isnt too late, let me know if you need anymore help
Steve
2001 diesel smell
I would check the color of the diesel in the fuel tank first. Siphon a small sample out into a clear container. If it has a yellowish apperance to it and is not transparent combined with the fact that you are losing water I would strongly suspect the injector tubes in the cylinder head. The coolant passes around them so when they leak you can get water in the diesel and diesel in the water. That would the most likley cause, the other possibility is a cracked head. The air conditioner does use water at all. It condenses water on the coils from the air and drips down, more so on humid days.
Top Land Rover Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Land Rover Expert? Answer questions, earn points and help others
