Laptop users may find that an average service life of the battery is generally short, whether original or less known and inferior brand. Short service life of the notebook, largely depends on the quality of laptop batteries and laptop users use habits
SOURCE: how to replace CMOS battery
Memory error
if the laptop is running and even boots up and the beeps continue it is the CPU (Overheat, not seated, cache memory error)
SOURCE: Toshiba laptop does not run, just amber light blinking
Did the computer ever work? Have you checked that your memory is properly seated? Remove the bottom plate that reveals the memory modules, pop both loose then back in. Try to restart. Is the battery fully seated?
SOURCE: my laptop battery only charges to 70% now
Dear,
Everything has a life,such as Human ,You and me,so its life is short time.Battery has a life of period.It has a lithium cell ,some of cell damage.Change it.
Thanks ,Best luck .
SOURCE: The battery life on my Acer 5735 laptop
Hi there, please go control panel & select the power option.Set that asper below image . After that apply & ok.
Thanks & waiting for your feedback.
SOURCE: My battery is not charging in my laptop, Great
If the laptop is about 2 years old (can be less) then I would say your battery is dead and needs replacement. That is very common and typical of all brands.
Replacment cost is sometimes covered under warrenty so check if you are still covered. A new battery is worth $60 to $160 depending on make model and age.If you are paying for it check around as the price can really differ from place to place.
Testimonial: "yes is about 4 years old so i need a new one Thanks"
