Hitachi 43fdx15b
Try this procedure:
Adjust the green & blue CRT screens to match the red. Go
into your picture menu adjust, turn color all the way down to a black &
white picture. Now adjust each CRT screen so that you end up with a true black
& white picture. Then adjust each focus control to get a sharp picture, and
adjust each CRT focus one at a time for clarity by covering the other two up. Then
go back into picture adjust and turn color half way up, you should see a
better picture.
If you cannot get the blue & green to even out to a
black & white screen you have other problems such as faulty CRT card on
back of tube or it could even be that the video IC is faulty. If this is the
case, then you may have to get a competent local technician to check the TV and
get the necessary parts replaced. It could set you back between $200-$400, depending upon how many components need replacing.
You can also try a hard reset..Unplug all cables, including power from the back of TV. Wait for 4 hrs and reconnect them. Try and see if it works now.
Hope that helps...Should you have any further questions,
please feel free to post them here.
P.S. Before you assign a rating, please
make sure that the issue is resolved or you are satisfied. If not, please post
back as to what you did, and/or any other questions you may have, and I will
try to assist you as best I can. Please do not assign an ‘Inappropriate’ or
‘Thanks for trying’ rating if your issue is not resolved after the first
response itself, as sometimes a bit of to and fro dialogue may be necessary
before we can find a fix or an answer to
your query.
If you find that the solution/answer I provided led you
to, or resulted in a fix, please close the ticket with a FixYa! or Helpful
rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
