Question about Whirlpool ET1WTKX Top Freezer Refrigerator
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH & KEEPS RUNNIN
Whirlpool top freezer ET1WTKXKQ01. Both fans running in freezer and under fridge. Cleaned coils on bottom. Freezer temp stays 28-32. fridge mid 40s. Turned temp dial down to 1 and still continues to run.
There was no ice build up in freezer. I removed back wall in freezer and there was a little ice on coil.Emptied and turned off refrigerator for about 8 hours. Turned back on let run for a couple of hours and still no change in temperature. Freezer still only 32ºF.
I have left it off over night and turned back on, no change.
6 hours later freezer still running, now at 28º f. Fridge at around 48º f. still leaving empty. first noticed about a week ago ice cream staying mushy. Refrigerator is about 7 years old.
Is it possible to be stuck in defrost mode? Please Help
  • Cindy Mar 31, 2009
    No, there is only some frost on the top right portion of the coil. And temp has reached about 53º f
    Thank you
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Remove the back wall leave the unit to run half hour open and see if coil have frost all the way from the top of the coil to the bottom if the coil is full you have adefrost problem could be your timer defrost thermostart or heater
Posted on Mar 31, 2009
6ya staff
SOURCE:
The freezer is not cold enough but i don't see a temperature control inside. Does the one in the fridge also control the freezer?
Correct. The fridge works 100% off the freezer anyways. So they installed the sensor right between the freezer and fridge if you look inside you can see it.
Whirlpool refrigerator repair orange county, ca
Feb 06, 2010 | Whirlpool ER6AHKXPQ Top Freezer...
Tip
Whirlpool Fridge
I am having trouble with my Whirlpool Fridge single door fridge. The top freezer is getting too cold and freezing the food too much and the bottom of the fridge is not cold enough, changing the settings on the fridge only makes it worse.
I have just recently chenged the fan, so what could be the proplem and how can I fix it.
on Feb 11, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Freezer and fridge doesn't get cold enough, I keep sliding the setting colder but fridge doesn't react
Is there a lot of frost accumulation on the back wall of the freezer section. If there is your auto defrost has a proble. All inexpensive repairs. Is the evap fan running in the freezer. You should be able to hear this when you open the freezer door. If you do not hear the fan you need a new evap fan. This is what circultes the air for proper cooling.
Feb 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My Whirlpool side by side fridge and freezer not working
Most likely, if you can hear the compressor running, the fan inside the freezer is not working. When the compressor is running, open the freezer and listen for the fan running. If you don't hear it, locate it and, with a voltmeter, test for voltage across the terminals. If you have voltage present, replace the fan. You can buy replacement fans at a local appliance parts store, internet parts suppliers, even ebay.
Jan 29, 2010 | GE Refrigerators
Whirlpool Compact Refrigerator w/ top freezer not cold enough in either compartment. Model: ETOWSRXMQO
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath or you may need freon
Aug 08, 2009 | Refrigerators
Problems with Whirlpool 21.0 cu. ft.
checklist: freezer fan running, compressor fan running, compressor running, any frost buildup on back wall of freezer. you may have to take a rag and touch the compressor to feel if its vibrating to see if its running unless you can hear it. please reply
Jun 12, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
You need to look inside the freezer at the rear wall cover and see if it is frosted over. If your refrigerator is not defrosting that can cause the refrigerator side and the freezer side also not to cool to the desired temp.
Mar 30, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
Whirlpool side by side freezer not working fridge is fine
Pull out the fridge and unplug. Remove the back cover. Clean the condenser coils and fan. If they're difficult to get to, use compressed air to blow out. (you can get a can from walmart). That should fix the problem. If that doesn't work, then write back.
Doug
Jan 05, 2009 | Whirlpool GC5SHEXNS Side by Side...
Fridge not cold
my freezer is over freezing and my fridge is not cold. I have a whirlpool where the freezer is on top and the fridge is on the bottom. I need guidence in trying to figure out the problem.
Sep 29, 2008 | Kenmore 64802 Top Freezer Refrigerator
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool ET1WTKX Top Freezer Refrigerator Logo
400 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
jdthefixer
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
