Try check solutions at the Apple Support Communities. You could try starting here:
https://discussions.apple.com/message/24916393#24916393
Hope this works :)
SOURCE: Itunes wont play purchased songs
I have OS X on my Mac.
Quit all applications except Finder.
Open Finder and choose Go...Go To Folder
Type /Users/Shared/SC Info and click Go
(View as columns)
Select the SC Info folder and move it to Trash
Restart the computer and open Itunes
Everything worked fine after for me
SOURCE: iTunes halts purchase. Says media is on max number of computers.
ITUNES will have to resolve this issue they can reset your records if you never received the music
SOURCE: what can i do to get rid of itunes error 306
http://discussions.apple.com/thread.jspa?threadID=2152912&start=90&tstart=0
Launch Internet Explorer
Click the Tools menu
Select Internet Options
Click the Connections tab
Click the LAN Settings button
Make sure that that "Use a proxy server for your LAN" checkbox is unchecked
Click OK till you are out of everything, and then close Internet Explorer
Try again in iTunes to load the store
or:
Okay, I found the solution when running CA Security Center for me. You need to open your Parental Controls - Advanced Settings. In the user/default tabs select Web Filters. The select "Custom List" under the allowed section. Then add the following sites individually: itunes.apple.com, ax.itunes.apple.com, albert.apple.com Be sure to select the checkbox to allow the entire domain. Then restart iTunes.
SOURCE: I cannot download from itunes store or play songs
try to go on apple.com and see if your info is correct. someone might have taken your account over
SOURCE: While downloading 4 songs on my ITunes, I have a
Hi
Please check the links bellow regarding your query:-
http://support.apple.com/kb/TS1583
http://ipod.about.com/od/itunesproblems/iTunes_problems.htm
http://www.makeuseof.com/tag/how-to-put-songs-into-your-itunes-library/
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
