Question about Braun WK600 Cordless Electric Kettle
Kettle shuts off before boiling?
Not sure what is wrong but my 1 year old braun kettle just shuts off before the water actually reaches the boiling point. Sometimes it will switch itself back on (several times) and once in a while (eventually )the water will be boiled but most of the time it just stops and the light at the bottom goes off. Any ideas? Thank you!
  • 2 more comments
  • Anonymous Jan 08, 2008
    Mine shuts off too after the light goes on. Will no longer boil...
  • Wizard Prang
    Wizard Prang Feb 25, 2008
    I have one of these kettles. After about eighteen months, it started switching itself off before boiling. Before long, things got worse, and now it switches off when it gets warm.
    Braun Support is not much help, and a their service center says that it is not worth fixing. I am convinced that this is a design fault, but Braun does not answer my e-mails.
    The kettle is secured with special allen-key bolts with a "post" in the middle. Where can I get the tools to open this?
  • chozahuynya Apr 23, 2008
    I have same problem as ppl above. After i turn it on, it would shuts off and no longer boil. had it for two years+
    Ohh, and about a year from the time i bought it, it started leaking from where i can see how much water is in lol.
    This model is just good looking garbage that is made in China and cost 80$+
    On the other end I gave my mom previous plastic model that was made in Germany and it still going strong after about 5 years.
    I really doubt that i would buy another Braun product ever again
  • Anonymous Apr 19, 2009
    I have exactly the same problem. Steer clear of this non-functional hunk of junk.
  • 3 Answers
I had a similar failure. Switch it on and the lights flicker and go out before it boils. Took it apart (Tamper Proof TORX, available from Snap-On, Canadian Tire, probably most auto parts places that also sell tools). The On-Off switch has a mechanical lock out for the lid being open and also for when it is not mounted on the base. The kettle also has three bi-metallic temperature switches. One shuts off the kettle after it has boiled long enough. The other two sit up against the element assembly adjacent to each end of the heating element.They protect against boiling an empty kettle by sensing the higher element temperture when there is no water to conduct away the heat. In the case where the lights flicker and go out, but the switch stays 'On' these are the likely culprit.
In my kettle the contacts did not line up correctly. Instead of making good contact they were only partially overlapping like a couple of the olympic rings or a couple of rings from the Audi logo. This resulted in a localized increased resistance and high heat in one of the contact holders which eventually melted the surrounding plastic. At that point the wires going to the element behaved a bit like springs which forced the contact holder further out of alignment until it all became hot enough to trigger the thermal switch.
I fixed it by bending the contact holder, which is fused into the now hardened plastic, to the optimal position and hopefully it will not generate enough heat to remelt the plastic or trip the thermal switch.
I have boiled a couple of kettlefuls; so far so good!
What ticks me off about this is that I don't mind getting 'Made In China' ****; everything comes from China anyway. But don't charge me a ridiculous amount of money and try to pretend that I am getting a superiour product. If I had paid twenty dollars or less for it I would just chuck it and get the same one again because it looks nice, pours well, doesn't burn the hands, worked OK for couple of years, etc. Instead I walk away from this feeling really ripped off. I have a house full of Braun products(shaver, kettle multiple tooth brushes) but now I won't buy any more.
Oh and if you take your kettle apart and your house burns down it is not my fault. There, now I feel better.
Posted on Apr 12, 2009
Posted on Apr 23, 2008
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
This is caused by a defective overload switch inbuilt in the kettle, sometimes the senitivity is higher than factory settings causing it to trip and reset several times before coming to boil. probably better to put up with it than going in for a costly repair.
Posted on Sep 28, 2007
6ya staff
SOURCE:
Switching off before water has reached boiling point
hi, what about it, it does not harm your kettle
Jun 23, 2015 | Kitchen Appliances - Others
How to clean my Braun electric kettle
Hi, follow the instruction below to clean it up...
Unplug the tea kettle from the wall outlet, and detach the plug from the kettle.
Pour 1/4 cup white vinegar into the kettle, and fill the kettle halfway with hot water.
Agitate the kettle so the vinegar mixture hits the sides of the kettle walls, and let the water sit for 20 minutes.
Discard the vinegar water, and scrub the interior of the kettle gently with a nylon sponge.
Rinse the kettle with hot water, and repeat as needed until all buildup is removed. Let the kettle air-dry before inserting the cord back into the kettle.
Apr 17, 2011 | Braun WK200 Cordless Electric Kettle
Shuts off
Does the unit shut off only before the water boils, or does it shut off and on periodically? I just fixed my friend's WK200 Braun kettle. His would shut off and on, eventually coming to a boil. During normal operation, when you press the switch, it is connected to a rod which at its other end (ie the bottom of the kettle) is able to close the circuit allowing the current to pass through the heating element. In my friend's case, the contact had become weak - I just had to slightly bend the metal pole a little bit to provide a better contact when the switch was depressed. To repair the unit, I only needed a couple of torx screwdrivers and a voltmeter to measure continuity. (note, if you bend the metal pole too much, then the circuit will always be closed even when the switch is OFF - make sure you test for an open circuit when the switch is OFF)
Jan 29, 2010 | Braun WK200 Cordless Electric Kettle
Kettle doesn't turn off
Our first Smart Kettle was great and worked well for years, finally died so we bought another. Right from the first boil it seemed to boil for about 2 or 3 minutes before turning off and then either didn't boil or made beeping sounds when not being used so after a couple of weeks we returned it and it was replaced. Great. But now this new one seems to boil and boil before turning off so maybe they are just faulty now. Any suggestions?
Jul 04, 2009 | Breville "Ikon" Tea Kettle Electric Kettle
Water kettle does not boil water
I had the exact same problem. The kettle would warm water but not boil. I bet you have hard water - try putting 1/2 vinegar and 1/2 water mix and turning it on. I did this, fixed the problem!
Nov 29, 2008 | Kitchen Appliances - Others
Automatic switch off not working when water reached boiling.
There is no do it yourself fix for this problem. However, placing a folded cloth on top of the kettle (covering the spout) will cause it to switch off quicker, as it increases the pressure inside the kettle.
Apr 21, 2008 | Breville SK500-XL Stainless Steel Cordless...
Red light flickers, goes off, no heat
I had a similar failure with my Braun WK600. Switch it on and the lights flicker and go out before it boils. Took it apart (Tamper Proof TORX, available from Snap-On, Canadian Tire, probably most auto parts places that also sell tools). The On-Off switch has a mechanical lock out for the lid being open and also for when it is not mounted on the base. The kettle also has three bi-metallic temperature switches. One shuts off the kettle after it has boiled long enough. The other two sit up against the element assembly adjacent to each end of the heating element.They protect against boiling an empty kettle by sensing the higher element temperture when there is no water to conduct away the heat. In the case where the lights flicker and go out, but the switch stays 'On' these are the likely culprit.
I have boiled a couple of kettleful's; so far so good!
Oh, and if you take your kettle apart and your house burns down it is not my fault.
Nov 22, 2007 | Braun WK600 Cordless Electric Kettle
Braun WK600 Cordless Electric Kettle Logo
10,587 people viewed this question
Top Braun Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Braun Kitchen Appliances - Other Expert? Answer questions, earn points and help others
