The Kodak easy share z612 memory says compatible with SD MMC. I purchased an SD HD 8 MB Card today and when I put it into the card slot the screen says cannot format card?
The DX7440 works with MMC and SD cards, which max out at 2GB. While your 4GB SDHC card fits into the slot, it is electronically incompatible and will not work with this camera. You need to stay with SD cards, 2GB and smaller.
The Z612 uses MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to use cards 2GB and smaller.
The Z612 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and won't work. You need to stay with SD cards, 2GB and smaller.
The Ultra card is larger than 2GB, isn't it? The Z612 uses SD cards. If your card is larger than 2GB then it's not an SD card but an SDHC (Secure Digital High Capacity) card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use SD cards 2GB and smaller in the Z612.
According to the manual, the Z612 uses MMC and SD cards.
Be careful not to try SDHC cards. They look similar to SD cards and will fit into the slot but are electronically incompatible. SD cards max out at 2GB in size.
Which size has the memory card? More than 1GB?
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
But try an firmware upgrade. Maybe the supporting now the 2 GB memory cards. Why download firmware version 1.07? This firmware version improves memory card compatibility and provides general performance updates. KODAK EASYSHARE C330 Zoom Digital Camera Firmware
