Computers & Internet Logo
Posted on Mar 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Limited or no connectivity
I am using XP SP2.
whenever i plug the cable, it keep saying aquiring network add
but later on limited or no connectivity. I've tried many drivers but didn't work.
The green and yellow flash is on.
Anonymous
Level 2:
  • Expert 59 Answers
  • Posted on Mar 31, 2009
Anonymous
Expert
Level 2:
Answers
59
Questions
0
Helped
29506
Points
134
Hi
just follow these steps
right click on my computer & click properties>> go to hardware>> device manager>> click on network adepters>> select your ethernet card (lan card) right click on it. select the option uninstall >> a window will show that r u sure u want to delete this driver click yes over there. then on the top of the device manager window click on action >>select scan for hardware changes. in a just a few sec the system will reinstall the driver for ur lan card. it will start working fine. in case if it doesn't work u have to use the static ip in ur lan card. for that just go to control panel>> click on network connection>> right click on network adepter>> click properties >> select internet protocol version 4 TCP/IP then click on properties >> put the dot on use the following ip address then type the ip the ip address (like these 192.168.0.2 ) on ip address on subnet mask it will be 255.255.255.0 on default gateway it will be ur routers ip address (like 192.168.0.1) on dns use the routers ip address again then just hit ok there u go ur problem is solved.
Regards
www.fixmypcandmac.com
Smc router says limited connectivity and won't work.
I experienced the same issue before with my route,try doing these steps im sure this will work somehow. (flush the DNS cache)
How to do it:
If you are using Windows 2000/XP operating sysytem
-Fire up a Command Prompt (Start Menu>Accessories) and execute the command
ipconfig -flushdns
if you get 'could not flush dns' or message saying dns resolver cache could not be flushed.
If it is XP SP2 then go to Start > Run > CMD > type netsh winsock reset > enter, restart as prompted, if still no connection then go to Start, Control Panel (Network and Internet Connections then Network Connections -or- straight to Network Connections, double click on the Local Area Connection in use (usually the one that says Connected) and pick Support. Try the Repair button after Winsock fix. Use that winsock fix only if you are using SP2.
go to "start, control panel, administration tools,services,then look for DNS Client, and make sure it's started, and set to manual.
tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
If your connection remains non-functional, run the Windows Network Repair utility on your computer.
If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 • Computers & Internet
Limited connectivity within Wireless Network
reinstall ur lan drivers then contact ur service provider
I get "Limited or no Connectivity" when I connect via ethernet
where it say limited or no connectivety icon on the taskbar just right click and select repair. hope this helps
2answers
No connectivity after.....
If you have installed Windows XP Service Pack 2 and are experiencing any of the following symptoms, this bug is affecting your system.
After installing Windows XP SP2, your network connection reports a problem with "Limited or No Connectivity"
You have trouble connecting to the Internet or your local area network after installing Windows XP Service Pack 2.
Your network connection gets stuck "Acquiring IP Address"
I have receintly bought a dlink wireless notebook adapter so i could set up my wireless wifi network at home to connect my compaq presario 900 to from a PC. I have installed everything and im getting a...
Does it say limited connection to network? You're connecting it through a wireless router right? Do you see your wireless router when you search for networks?
I had similar problem with my previous Dell laptop. Wireless use to work untill one day it just stopped, found the networks, but kept giving me limited connection whenever i tried to connect. I found out the problem is linked with the driver. Dell laptop i had was also on XP OS.
Maybe try reinstalling the drivers. After I formatted my computer and reinstalled drivers, it started working again.
Hope this helps.
Asus 802.11 a/b/g wireless adapter problem
The problem could be with the wireless network that you are trying to access, or it has something to do with you wireless card tcp/ip protocol.
where you using the same computer now, when you had this issue with the vista? or is this win XP pc that you have now is a different computer?
if you are getting limited or no connectivity, that means that the access point (wireless signal) is not giving you a valid IP address.
you can try to add static to your IP settings, but this will only work if you knew the IP range of that network that you are trying to access.
please provide more info
2answers
No default gateway !
This usually means that your network is connected but your computer can't obtain an IP address or default gateway from the ISP (Internet Service Provider) or router. Without an IP address, your computer cannot communicate on the network.
Network problem
You didn't mention which windows you are using, I have XP Sp2 and have had the same problem this week in fact except I have a dlink router. So assuming you have XP Sp2 then try this patch it should solve your problem.
http://www.microsoft.com/downloads/details.aspx?FamilyID=17d997d2-5034-4bbb-b74d-ad8430a1f7c8&DisplayLang=en
Hope this helps
1helpful
7answers
Hi, I had the limited or no connectivity problem on my wifes laptop for about a year.
THE SOLUTION:
Go into your wireless router/transmitter and change the channel. eg. mine was on Channel 10, and the following all connected Acer Laptop, Xbox360, Wii, Blackberry but not the Vaio. I changed to Channel 4 an the Vaio sprung into action and everything else updated itself automatically.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
