I have a Jenair microwave and just recently the turn table is making a noise. I purchased it new approx. 1 year ago.
Just dont listen to Mr Miller. He rambles way off subject and will say anything to feel like he is special.
All it takes is very fist sentence where he suggests it could be magnetron bad. Geee, if that were the case your microwave wouldnt heat/cook so you wouldnt be here having a noise problem would you? Its kinda like the mechanic saying your noisy brakes could be caused by a empty gas tank.
Cause? - could be motor that operates turntable going bad, food or something lodged anywhere in moving parts of turntable operation which includes unseen area, or moving part that is been somehow bent or moved (unlikely without impact to microwave or previous work done possibly leaving something loose).
Solution? - I am ignorant of specific assembly of your microwave but on many you can access motor from bottom (unplug microwave first) and replace motor yourself if you are somewhat mechanical. The cheapest easiest 1st step would be clean very well around all parts and even clean any debris you find when taken apart, then recover and turn on to see. Not the likliest but its cheap and easy and you have to take apart bottom to replace motor anyway so not really much extra work.
SOURCE: kenmore microwave doesn't heat up
The most likely causes are a bad door switch, a loose connector on the magnetron, or a bad magnetron. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk Here's a reprint of one of our FAQS on the subject: Q. My microwave seems to be running okay, but it won't heat. A. If you are a do-it-yourselfer with the right equipment and care, you can do quite a bit of troubleshooting, but once you get near the high voltage section, it is time to be VERY sure of your actions. DANGER: Microwaves produce lethal voltages. They can kill. Before you go any further, you should read the safety warnings here: http://207.234.249.73/mwd/safety.txt If you find line voltage (100-125 VAC) on the primary of the high-voltage transformer while the oven is running, the problem is indeed in the high voltage section. If that line voltage is not present, then the problem is not in the high voltage section. Door switches would be one suspect, as well as a control panel problem. To check door swithces, see this file: http://www.microwavedisplay.com/doorsw.txt If you have or suspect control panel problems, see details of the repair service here: http://207.234.249.73/mwd/index.htm There are a few prime suspects to be aware of in the high-voltage section, mainly the high-voltage rectifier diode, the magnetron, and the high-voltage transformer. DIODE: Did the oven pop during the cooking cycle? If so, that's pretty good evidence that the diode has gone bad, not that's not the only way it can fail. High-voltage rectifier ID & diagnosis can be found here: http://www.gallawa.com/microtech/diode.html MAGNETRON: Sometimes everything looks and seems okay, but the magnetron is simply not producing heat. At other times, it may be arcing inside, and producing a noise that sounds something like someone growling into a coffee mug. It's also possible that the mag may have a cracked magnet. Check for that, too. More likely, it may be that the magnetron filament connectors have loosened (they should be snug) and, due to resistive heat, the terminal connections have deteriorated and burned loose to some degree. A photo showing that area can be found here: http://207.234.249.73/mwd/magterm.jpg . Here are some tips if you have loose connections: If the connectors feel loose, and any burning or melting seems minor, you should be able to carefully tighten the connectors with a pair of pliers, then sand or file the rusty-looking terminals of the magnetron until they are clean and shiny. If the burning is more serious, the connectors may need to be replaced. They can be obtained from home improvement centers and auto parts stores. They are 1/4" connectors and can be squeezed in place onto stripped wire with proper crimpers or a pair of pliers. Another option is to cut the connectors off the wires and solder the wires directly to the magnetron terminals. If this is done, do not apply heat to the terminals any longer than necessary. If the burning is really bad, the plastic surrounding the magnetron terminals is charred or melted, the magnetron may need to be replaced. HIGH-VOLTAGE TRANSFORMER: When the voltage transformer fails, it will often emit heat and smoke, but with the fan running, you might not smell it. With the cover off, it may be easier to smell. Also, you can look at the windings and see if they look discolored due to heat. If a high-voltage transformer is shorting, it can blow the fuse a few seconds after pressing the start button to start a cooking cycle. High-voltage transformer ID & diagnosis can be found here: http://www.gallawa.com/microtech/xformer.html HIGH-VOLTAGE CAPACITOR: The high-voltage capacitor will usually fail by shorting. When it does, the fuse will be blown right after you press the start button to begin a cooking cycle. If the capacitor is old and dries out, then it can fail by just not allowing the high-voltage to be doubled. I don't remember having ever seen this condition. High-voltage capacitor ID & diagnosis can be found here: http://www.gallawa.com/microtech/cap_test.html More information on the high-voltage circuit can be found here: http://www.gallawa.com/microtech/doubler.html Again, be safe!
SOURCE: Panasonic Microwave Turn table rotates when door is open
Found this Panasonic post in the Samsung section!
If it moves just a tiny bit when the door opens and then stops, that's normal.
If it keeps running when the door is open, that's usually due to a bad door switch or broken / loose door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Any Panasonic parts not available locally can be had here: http://www.pasc.panasonic.com/epartr
We appreciate your thoughtful rating of our answer.
SOURCE: microwave turntable won't turn
You may have a tunrtable motor or spindle problem..
This info is from GE website..( link : http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
To minimize the possibility of electric shock, unplug this appliance from the power supply before attempting any maintenance or cleaning.
SOURCE: Microwave turntable makes noise
yes motor may be bad or something is stuck . its not difficult to change .it is located at the bottom and has a wire connector with 2 spade clips
SOURCE: Microwave oven light stays on and turntable keeps turning
It would appear that relay # RY1 is stuck on your control circuit board.
We regularly repair such control units for
customers nationwide by mail for $39.95 postpaid in about a
week or so with a one-year guarantee.
We have
the service / repair manual for this model and have uploaded it to our
site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader
Feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more information & help.
We're
happy to help you with free advice and we'd appreciate your thoughtful
We're happy
to help you. Once we have all your information and
offer a final solution, we'd appreciate your
William E. Miller, AS-EET
[email protected]
