When i power up the cdj it ejects the disc. when i put a disc in i can hear i spin a little and then it ejects! i have changed the laser and its housing and it still dosnt work! can some please help me ive already spent 80 on fixing it and i still have no results!
Well, the optical pickup is not able to read the disk. First off, did you use ESD protection when you installed it? If not, it may already be damaged. For more information, or should you have further questions, please visit my website at audioserviceclinic.com. You may contact me directly through the website. Thank you.
SOURCE: CDJ 800 Bad Laser
Yes, sounds like a damaged reader/tray. This is not an easy fix. Although there is no soldering involved, it's sort of like a car. In order to get to the engine, you have to remove a whole lot of other sections first. Often times when you put it back together, you'll find yourself with some extra pieces you didn't have when you started. With that said, I do not suggest you do this yourself, unless you are completely 100% confident in your ability. Or, get some help.
The part is available HERE - at the cost of $49.99
- TWEAK A/V LAB
SOURCE: The CDJ won't load the disc!!!
You have to get it repaired,no quick fix im afraid.
email: [email protected] for all dj equipment repairs.
Thanks.
yes sounds like a laser pick-up problem,if you havent had it repaired you can send it to us.
thanks.
http://www.audiovisualservices.info/
SOURCE: cdj 800
Traverse assembly (laser reader) is more than likely damaged and needs to be replaced.
The part is located here:
Pioneer CDJ800 CD Reader Part
Pioneer CDJ800MK2 CD Reader Part
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
SOURCE: New Laser
If a new laser does not work, there should be a small ball of solder applied at the factory shorting the static sensitive laser diode. Find that and unsolder it after grounding yourself and your soldering pen.
