Nokia N70 Cellular Phone Logo
Anonymous Posted on Jul 21, 2013
Setting 3g create a 3g profile
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 21, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
40
Points
I WANT TO CONNECT MY NOKIA 7360 TO THE INTERNET
1.Firstly Activate your 3G/GPRS facility
2.Get the GPRS setting manually or though customer care and install it.
3. For PC connecting Install NOKIA PC suite first
4.Then through USB connector connect to the port provided
5.When it is connected then go to profile/connection setting,create or select the profile provided
and make it as default.
6.Finally connect it and enjoy you surfing.
tip
Restore WAP, 3G, MMS Settings | Sony Ericsson Phones
Many people are having problems configuring their phones after de-branding or after flashing it. Usually after de-branding your phone you lose all the WAP, Internet, MMS settings from the phone. And you won't be able to send MMS or browse Internet.
For MMS and WAP to function properly, you should first create Data Accounts in Phone Settings and Then create Internet Profile and MMS profiles which make use of the Data Account. For manually creating these accounts and profiles you will need a lot of technical information from your CellPhone Service Provider. You will need to know the APN, Proxy Address if any, Username and password settings. Hence the idea of manually setting up is not recommended, unless you have spare time to figure out things.
You can directly download WAP and MMS settings for your phone from local Sony Ericsson Website. Visit SonyEricsson.com. In support section specific to your country, you will find links on how to configure Internet and MMS. Visit those links, You will be asked about phone model and operator name ( like Vodafone, Airtel in list), Select your operator and provide your cell phone number. You will be given a authorization code, and in a few minutes Sony Ericsson will send you the Internet/MMS settings directly to your phone. Enter the authorization code in your phone. And MMS, WAP, 3G and Internet settings will be installed correctly. All operator based services should then work fine.
Thank you for using FixYa!, Keep visiting..
Concerned, Nooh.
on Jan 23, 2011 • Cell Phones
tip
Create a duplicate user profile with a different name
To create a duplicate of an user profile with a different user name, try this:
  • Create a new user account
  • Logon to that account to initialize the newly created profile
  • Log off from the newly created profile
  • Login as built-in Administrator
  • Open Control Panel System applet
  • Click the Advanced tab
  • Click Settings under User Profiles
  • Select a profile to copy from and choose Copy To
  • Browse to the profile to copy to (C:\Documents and Settings\username)
A new profile is now created which is the duplicate of your user profile.
Sir MMX 310G 3G usb modem, when i was connected, the message shows only "dial failed". My profile setting is right, but what's the problem.Please solve the problem. Connection Profile...
there would be some software problem.......... please reinstall the software and use your device......... dont forget to vote for me...........
2answers
I hav huawei e1550 3g idea net setter i hav unlocked my data card successecfuly but no gsm other than idea work in that data card i want to use bsnl 3g sim in my data card please can u heip me...
it seems you have got an unlocked datacard, the very same i am using ,put a bsnl 3g enabled sim in it and connect it to pc
if the network appears on left down corner it means you can use
now go to tools options profilemanagement and create a new profile with any name but change dynamic to static and enter apn as "bsnlstream" save the profile set as default click connect it should connect and u must get 2.6 MBps speed,if speed is low search for tower and this is the only way and working way because i am using this now and i am typing through this internet noww please thank me on [email protected]
1helpful
How to do internet settings manually on nokia e71
BEFORE YOU BEGIN, please note the following:
On the Nokia E71 some of VoIP settings are hidden by default, and you will need Nokia's new VoIP SIP application.
This application can be used to configure VoIP settings on your Nokia. You can create new VoIP profiles and modify the existing ones, and create and modify VoIP parameters and NAT/Firewall traversal settings and that are normally not visible on the device UI, such as codec settings and SIP domain-specific NAT/FW settings. It is also possible to save all the VoIP profile settings to a text file. It also enables VoIP over WCDMA which means you can make VoIP call over 3G Internet connection.
Using your PC you can download free Nokia SIP VoIP application from here or you can check Nokia web sitefor latest version.
Extract and install SIS file using Nokia PC Suite software on your PC.
Once installation is complete you will be able to see "SIP VoIP Settings" application under Applications menu on your Nokia, which you will need in STEP 5 of this configuration guide for better voice quallity or enabling VoIP over 3G Internet connection.
Here you can find Nokia E71 SIP settings for voip setup and SIP client configuration guide with VoIPVoIP service.
STEP 1 Go to Tools / Settings / Connection / SIP settings. Create the following profile
Profile Name: VoIPVoIP Service
Profile: IETF Default
Access point: (your WLAN AP name)
Public user name: [email protected] ( Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. When recorded your phone will show sip:[email protected] )
Use Compression: No
Registration: "Always on "
Use Security: No
STEP 2 You do not need to enter Proxy Server settings
Proxy Server Address: none
Registrar Server:none
Realm: none
User Name: none
STEP 3 Enter the following for Registrar Server settings
Registrar Server: sip3.voipvoip.com (When recorded your phone will show sip:sip3.voipvoip.com)
Realm: voipvoip.com
User Name: 5551231234 (Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. )
Password: Enter the password that you chose when you signed up for the service.
Transport Type: UDP
Port: 5060
STEP 4 Go to Tools / Settings / Connection / Internet Tel. Settings
Create a new profile for "voipvoip"(555123xxxx), name it "voipvoip"
Choose "voipvoip" as Preferred profile
STEP 5 For better voice quality or in order to be able to make VoIP calls over 3G internet connection you need to use Nokia SIP VoIP Application you installed.
Go to Applications on your phone and click on "SIP VoIP Settings" application. Choose VoIP services/VoIPVoIP (or the name of your VoIPVoIP account Internet profile.)
Click on "Profile Settings" and find "Allow VoIP over WCDMA" option and change it to "ON" This change allows VoIP over 3G connection on Nokia phones.
For better voice quality go to Codecs and delete all codecs except G729. There should be only G729 codec left under codecs setting
STEP 6 Reboot your phone. Once your phone is back on it will automatically register to VoIPVoIP.
Once it is registered you can start making calls.
Default call type: To switch between normal GSM calls or VOIP calls, navigate to Tools / Settings / Call / Default call type. Select Cellular to make normal calls to the phone number or Internet to use VoIP to call the number or address
Make Calls!
To dial any phone number that is part of the NANP (North American Numbering Plan), you must dial:
1 + Area Code + Phone number
To dial any phone number that is outside of the NANP (North American Numbering Plan), you must dial:
Country Code + City Code + Phone number
For example if you want to call Brazil (country code 55) phone number in Rio de Janeiro (city code 21) you must dial 5521 and phone number. + sign can also be used and number can be dialed as +5521xxxxxxx
BUT RATHER THAN FOLLOWING THESE PLS CALL TO YOUR CUSTOMER CARE THEY WIL GIVE THE SETTINGS. SAVE THEM. THEN FOLLOW THE INSTRUCTIONS. THIS DOES NOT COST ANY COST. PLEASE TRY THIS
How to activate my mms? globe prepaid
  • For a complete listing of compatible MMS & GPRS phone handsets — send Nokia, Ericsson or Samsung (your handset model) to 2365.
  • To get your phone’s settings, text GO (handset model) to 2951. Example, GO N3650. (For a list of compatible handsets, refer to #1) Note: For Nokia 6220, 6600, and 6820, text GO < handset model >,1234 and send to 2951. Make sure to type in the two commas before the 1234 PIN. Regular text messaging charges will apply.
  • Enter 1234 when asked for PIN to save settings.
  • Send an MMS message for only Php 5.00 to activate the service.
or
This tutorial will help you setup your mobile phone and activate/configure GPRS, 3G and MMS features for Globe Telecoms.
GPRS SETTINGS
1. Go to Menu > Choose Settings > Connectivity
2. Go to Data Accounts
3. Create New Account. GPRS/ PS Data
Account Name: MyGlobe GPRS
APN: www.globe.com.ph
4. Save Account
5. Go to Internet Settings
6. Create New Profile
Connect Using: MyGlobe GPRS
7. Save Profile
8. Select the profile MyGlobe WAP in Internet Profile
9. Click Right Soft Key to Choose More and Select Settings
Internet Mode: HTTP
Use Proxy: Yes
Proxy Address: 203.177.042.214
Port Number: 8080
10. Save Settings and repeat Step 9 but this time choose Advance Settings
11. Change Homepage
Title: MyGlobe
Address: http://www.globe.com.ph/globe.asp
12. Save Changes
MyGlobe Internet Settings
3. Create New Account. GPRS / PS Data
Account Name: MyGlobe INTERNET
APN: internet.globe.com.ph
4. Save Account
MyGlobe MMS Settings
1. Go to Menu>Choose Settings>Connectivity
Account Name: MyGlobe MMS
APN: mms.globe.com.ph
4. Save Account
Connect Using: MyGlobe MMS
7. Save Profile
8. Select the profile MyGlobe MMS in Internet Profile
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
10. Save Settings
11. Click Right Soft Key to Choose More and Select Advance Settings
12. Change Homepage. Enter the following parameters and save the settings
Address: http://192.40.100.22:10021/mmsc
13. Go to Messaging>Settings> Picture Message
14. Edit Message Server : http://192.40.100.22:100.21/mmsc
15. From Message Settings, make your Internet Profile: MyGlobe MMS
MyGlobe Stream Settings
3. Create New Account. GPRS/PS Data
Account Name: MyGlobe Stream
APN: real.globe.com.ph
4. Save Account
5. Go to Streaming Settings
6. Make MyGlobe Stream your default APN.
8helpful
3answers
Cect i9 3g o2 internet help
This seems to be the settings for web, let me know if they work.
1- Set GPRS Account
Goto Home
Goto Entertainment
Goto Services
Goto Data Account
Choose GPRS
Create a new profile on mine I'm currently using a PAYG SIM so have called it PAYG O2 on Profile 8
APN (Contract) wap.o2.co.uk (PAYG) payandgo.o2.uk
Username (Contract) o2wap (PAYG) payandgo
Password password
Auth. Type Normal
2 Edit Browser Profile
Go Back to the Entertainment > Services Menu
Choose WAP
Choose Settings
Choose Edit Profile
Create a new one, I've called it PAYG O2 and choose O2
Choose Edit Profile
Rename if required
Homepage: http://wap.o2.co.uk
Data Account: Select the Account setup in 1 Above
Connection Type: Choose HTTP and set proxy to 193.113.200.195 and port to 8080
Username and password should remain empty
There should not be any difference between contract and PAYG
_________________
Cant send picture message. need profile name.
You don't have any active MMS profile. You need to create it manually or you need to contact your service provider for MMS profile. Generally your mobile service provider give you free MMS profiles if you call them. You also need to check if you have MMS service activated on your mobile plan or not. You also need to check if you have working 3G/GPRS connection on your phone or not.
Summary: contact your mobile service provider for correct MMS settings for free.
Want a profile
if u want to create a handset profile,simply create it frm settings in ur handset.OR if u want to create a internet profile call ur service provider to send u settings of the service.....profile will b created automatically in ur handset.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
