Here are your Amana flash codes:
Steady On - Normal
Off Controller Failure
1 System Lockout
2 Pressure Sw stuck closed
3 Pressure SW Stuck Open
4 Open - High Limit
5 Flame sense without gas valve
6 Open rollout or open Fuse
7 low flame signal
8 Check igniter or improper ground
continuous flashing - reversed AC polarity
The E5 error code is only referenced by a technician. More than likely it refers to a circuit board problem. Only solution is to have it replaced by a technician.
E1: tape end detection LED open E2: front loading motor lock E3: loading motor lock E4: cylinder motor lock E5: reel motor lock These are from a Panasonic AG-7500 service manual.
Ok what you need to do is call your local service company and have a technician come out and check your Thermostat, its currently not able to read humidity probably due to a power surge
