Emerson LC320EM9 32 HDTV LCD TV Logo
Anonymous Posted on Jul 19, 2013
No sound from my Emerson tv
I cant get no sound. volume from my tv
Anonymous
Level 3:
Top Expert:
  • Emerson Master 14,553 Answers
  • Posted on Jul 20, 2013
Anonymous
Emerson Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718001
Points
48227
Try a dvd to see if sound via the audio/video jacks and also look in set menu to see is speakers are turned OFF or not, the sound if works with a dvd means it is a hookup or similar issue and the audio circuit in the set is good. Also if set has headphone jack see if that works.
Hello, I have an Emerson Plasma TV, Model: PL-P42W-10A. Out of the blue, the audio completely stopped working. Do you know what part I would need to replace so I can get the sound working again?
In the audio properties, or audio adjustments. Make sure the speakers are turned ON. Can you turn the volume up with the buttons on the TV. If the speakers are turned on and you can see the volume indicator going up and down on the TV screen and all plugs and cables are plugged in the sound amplifier inside the TV is probably at fault,
aud
2answers
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
How can I fix volume control
How do I stabilize volume on a television? : hometheater
https://www.reddit.com/.../how_do_i_stabilize_volume_on_a_tele...
RedditAug 31, 2014 - We have a Samsung Smart TV - 52". My mom is a hardcore movie watcher, and I have very sensitive hearing. It's a constant battle because I'm ...Missing: lc320slx
Funai Emerson LE220EM3 Owner's Manual - ManualsLib
www.manualslib.com > ... > LCD TV > Emerson LE220EM3
Emerson LE220EM3 LCD TV pdf manual download. ... LCD TV FUNAI LC320SLXService Manual ... Model # Screw dimension •. ... Tv, Switching On Your Tv And Putting It In Standby Mode, Adjusting Volume, Switching Channels ... Clock setting tostabilize the PC screen and Phase Canadian French rating, then press OK.
I bought a 50" Emerson TV, since day one the volume cuts out for 1-2 seconds every once in a while. Frustrating while watching it. How can I fix the TV to stop blanking out the volume?
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
2helpful
I have an Emerson 42"
Let verify first to narrow down to where the problem can be. First, check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. To get the sound repair, it can be from $150 and up, so if you can put up with using the good set of Powered PC speakers which actually give better sound than the tiny speakers inside the TV, I would keep using it that way, you may want to find out if the on screen sound setup will allow you to set the audio line out to be VARIABLE which means the sound output feeding the PC speakers can be varied using the TV remote control, then all you have to do is to set the PC volume to about half way up and set the TV volume to what ever you want.
Hoping this will work to solve the problem..
1helpful
My 19in lcd hdtv emerson wont stop turning the volume down by its self.And then i took my batteries out of the remote and it is still doing the same thing. i cant even press buttons on the remote. Also...
See if the minus volume button on the TV is stuck. With the TV off press the various buttons while keeping your ears close to them. Each will produce a distinct click when you press them, confirm if the volume - key also produces the same sound - if not the key is defective or stuck.
1helpful
Television sound is static y
This status could be caused by the volume limiter inside the unit thus causing static, thus you will need to have it repaired. The cost of this repair ranges from $50-$90 bucks depending on the actul cost of the part causing the interference,
Thanks and please do be considerate while your are passing threw fixya today to leave postive feedback for those who have helped you today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
I cant hear the tv
Hello drive2darim,
OK first check you converter box, Cable TV/ Satellite TV volume control and turn it up to 100%.
Then check the menu on your TV for audio settings and set them to there default settings. This should take care of this issue.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Need code for ewc13d4 tv/dvd for direct tv remote
Direct (and Dish) may not have codes available for all brands and models; I know that from personal experience.
You need to got to Direct TV's website to obtain a current list of codes. Even if they have some for Emerson, they may be quite limited in their usefulness.
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
