Tomtom One XL GPS Receiver Logo
Posted on Mar 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have TOMTOM ONE XL. Lost Pin code and can't reset it. Don't have original computer that I set it up with. How do I unlock the GPS?
Anonymous
Level 2:
  • Expert 515 Answers
  • Posted on Apr 13, 2009
Anonymous
Expert
Level 2:
Answers
515
Questions
0
Helped
250000
Points
771
blochage
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 22, 2013
blochage
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2324
Points
Tom Tom PIN number please
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on May 29, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2346
Points
What the pair number tomtom 180
Tomtom xl 2 iq stuck and cannot switch off
Somewhere in the back where the mounting bracket goes in, is a small reset button, press this in with a pin for a few seconds, it should reset all
1helpful
How do you put factory settings on a tomtom gps
Hello
There is option to reset the set to its factory settings. Reset factory setting ikon [ a red round ikon with counter clockwise ringed arrow. Tap this to reset your TomTom XL. For more details, go to the page [36] of its user manual. All proceedings are described there. OK.
1helpful
Im locked out i have lost my pin code for my garmin nuvi gps
Going back to the security location will unlock the unit but in order to reset the pin code, the original pin code must be input.
To unlock the unit, it must be sent back to Garmin.
I lost my manual how do I reset my bottom xp 310 Canada
There should be a small button behind the headphone connector above the memory card slot. Use a small object (small screwdriver, clothing pin, toothpick, etc) and press down on it.
You may also download the manual via the TomTom website:
http://us.support.tomtom.com/app/home
Then go to "Manuals & user guides" enter your device model. It should bring up the manual or a similar model of it.
My tom tom one xl won't turn on anymore but when I connect to the computer it turns on and shows a picture of a gps. still can't use it though. it is fully charged.
try hitting the reset button with a pin for about 15 seconds (this is located near the memory card slot) switch on to see if it boots up then install the latest updates from tomtom home, good luck
4helpful
Restore to factory setting
n rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? ico_close.gif Type the first two characters of your device's serial number below to find out.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
The rest button is on the top of the GPS
2helpful
1helpful
Lost gps and then found 6 months later and cant remember password
To reset your ONE XL, use a straightened paper clip, or something similar, to push the reset button. The reset button is next to the memory card slot, on the bottom of your ONE XL. Then turn your ONE XL on it will be back to it's factory settings.
4helpful
New TOMTOM ONE XL NO Sound
Put pin in pinhole on base of device to reset
Worked for me
JonestheBones
2helpful
How do I unlock the security lock on my Tom Tom navigation device?
If you don’t know what the 4 digit password is you will have to reset the unit. This will clear all saved information.
Reset factory settings
To show all menu options, tap Show ALL menu options.
Tap this button to restore the factory settings to your TomTom ONE XL. All your settings, including Favorites, your Home location, warnings for POIs and any Itineraries you have created, as well as recent destinations and recent calls and callers, will be deleted.
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
