Panasonic DMR-EZ47V DVD Recorder/VCR Logo
Posted on Mar 30, 2009
How do I connect an external radio shack AM enhancer
To a radio that does not have external connectors?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 07, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
69
Points
I presume that you wish to connect an external antenna/aerial to a portable radio with no antenna connection. Wind several turns of your antenna wire around the telescopic antenna - should work ok!
Owners manuel for Radio Shack Pro-2039
Nope... seems that since Radio Shack folded up it's tents almost all of the old links have dried up! And GEE, I had one of these scanners but have no idea where it is now?
A FEW of the exceptions follow...
PROGRAMMING
This Link is for the Pro-2021 BUT your PRO-2039 programming will be much the same!
Radio Shack Realistic Pro 2021 Scanner Programming and Overview
This link may help you too but it's a much more advanced scanner!
RadioShack Pro 2050 Scanner Programming Tutorial Police Scanner
PRO-2039 SPECIFICATIONS RigPix Database RadioShack Realistic Pro 2039 20 7462
GENERAL Type:VHF/UHF receiver/scanner Frequency range:66-88 / 108-174 / 380-512 / 806-960 MHz (Europe) Tuning steps: Mode:AM/FM Channels/memory management:200 regular in 10 banks @ 25 ch/sec
10 monitor Power supply:Mains Current drain/power consumption:Max 13 W @ 230 VAC Antenna impedance/connector:50-75 ohms / ? or built-in telescopic whip Dimensions (W*H*D):190*80*180 mm (7.5*3.12*7.12") Weight:1 Kg (2.2 lbs) Other features: RECEIVER SECTION Receiver system:Double conversion superheterodyne
1st IF: 10.7 MHz
2nd IF: 455 KHz Sensitivity: Selectivity: Image rejection: AF output power/speaker:1 W at ?% distortion / 8 ohms External speaker connector: MISCELLANEOUS Manufactured:China, 199x-199x (Discontinued)
For "PURE AUDIO" there is a MODIFICATION/Link:
http://schreiber.pl/mods.dk/mods.php3-radio=radio_shack&model=pro-2039&selectid=1855.htm
ANTHONY
1helpful
How i can install external page port of a pabx Norstar with output of 600ohms to the input Radio shack 250 Watts PA.
Connect Nortel PABX external page port output to the amp input.
Either by phone plug or RCA connector, any of the two will work.
1helpful
Am fm reception bad
FM reception is weak
What to do
• Extend the power cord as much as possible. The FM antenna is in the power cord.
• Move the power cord to adjust the FM antenna
• If you still have problems with FM reception, you may need an external antenna.
* Call Bose®Customer Service to request one.
The external antenna on your radio is a coax (round) design It needs an adaptor and an antenna which are cheap.
Easy to make, radio shack "F" connector 90 degrees or straight, to 300 ohm wire connections. Attatch a 300 ohm flat ribbon antenna cable to those two screws and plug into radio and see how your reception is. You will need to position the antenna wires to get best reception. I have hid them in back of paintings and so on.
Cheapest solution next to putting an extension cord on radio power cord.
3helpful
3answers
Nokia 5200 - radio not working - connect an enhancement error
I Think there is some problem in Radio settings, so just make sure to reset mobile settings
1helpful
I want to connect camera and VCR to my GE 5
Yes. Take the monitor, camera and VCR to any radio shack store and they will show you what cables you need. In the event that the monitor has no external plugs to recieve signals they can recommend a local shop that will add the connectors to the tv.
5helpful
4answers
Samsung syncmaster 910mp TV connection
I believe you are describing this connector adapter.
http://www.thesource.ca/estore/ catalog number 2780265
Where can i get an external antenna adapter to fit my tv/dvd from
Well I thought I had one of the mini-jack to F type connector cables ordered but then it became Discontinued at PacParts.com. However, if Radio Shack still carries those F-connector to mini-mono earphone plugs then with another F-type Quick Connect you can make one with a length of RG-*.*/U cable with F-type screwon male connectors. Almost every one has some of those cable or satellite pieces laying around or stored and with proper adapters can fashion one for their portable TV's.
External antenna
You can get good assistance at the DX 398 Group at Yahoo! The DX 398 is the same radio as the ATS-909. It was the name used by Radio Shack when they marketed it. Here's the URL for the DX398 group: http://groups.yahoo.com/group/DX398/ They will definately welcome your questions and will likely provide some valuable answers.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
