Just enter the default IP in a web browser. It should be 192.168.0.1 User: Admin Password: [none / blank] Unless it has been configured. To clear setting, just hold the reset in the back till it cycles.
Check parental controls for internet explorer. Open ie click tools at the top, then internet options then content. Under the content advisor option make sure parental controls are disabled
you will need to change some settings on the router. reduce the MTU. if the MTU settings on the router is 1500 then change 1365 also you will need to open the some ports on the router. Click Here for more info
If you are on Verizon network it won't work, because of pppoe network. That mean your ip address changes. You have to have a static ip before it will work right.
I can see no problem with that. But the WPA2 could be the issue. Some wireless device doesn't support WPA2 level. You can give it a try. For sure the laptop will connect. Not sure with the printer and the skype device. If they can't connect, use WPA only.
I did that once, left it like that for about 3 months till I was bored and decided to mess with it. I then remembered It had a Reset button. Press that and everything should be back to narmal.
What kind of problems are you having? Once the router is connected to your modem and the router is configured and working properly you should be able to connect it to your PS3.
