I was heating a casserole warmer gel pack yesterday morning. It said to have it in the microwave for 2 to 3 minutes. I set it for 3 minutes, took the trash out and when I came back in the gel pack had expanded to a huge bubble and looked like a jiffy pop popcorn item. The metal tray had been lifted off the holders and pushed the tray to the top of the microwave. I took the gel pack out, and the fan continued to run. When I got home last night the fan was still running and is as loud as a vacuum cleaner. I could not get it to shut off. Opening the door and closing didn't make any difference. The light remains on as the fan loudly blows. It now has been running for 24 hours straight. Is there a way on the control panel of the microwave to reset this? Or is my only option to go the service breaker and find the fuse? Is this a dangerous situation? Rose
Buffalo was pretty close, but glad the reset worked.
THE FAN AND MICROWAVE TUBE RUN OFF THE ELECTRONIC TIMER. OPENING THE DOOR SHOULD SHUT IT ALL DOWN AND WHEN YOU CLOSE THE DOOR AGAIN YOU SHOULD NEED TO PRESS THE START BUTTON AGAIN. IF NOT, ITS SOUNDS LIKE AN ELECTRONIC RELAY IS LOCKED CLOSED ON THE TIMER BOARD.
Opening and shutting the door did not work when tried. I was able to reset it by going to the fuse box and turning the fuse off, then back on. It was enough to shut it off and allow it to return to normal. Everything is working.
