Question about Pride New Mobility Victory XL 4 Wheel Scooter
Smoke came out of pride victory stearing column
Does it control charging all other works lights horn power gauge works
  • Rene Pepin Jul 18, 2013
    Will I still be able to charge my scooter
    Habit-Forming:
    New Friend:
  • 88 Answers
Sell it and run!
Posted on Aug 02, 2016
6ya staff
SOURCE:
Dan Hudson
  • 118 Answers
SOURCE: Pride victory mobility scooter
A fully charged battery should be over 12 volts. You may need to change your batteries.
Posted on Nov 27, 2008
Lee Glascock
  • 384 Answers
SOURCE: dead and wont move cant charge but batties are ok
sounds like a dead battery on the unit. see if you can get it replace .
Posted on May 24, 2009
oregoon
  • 175 Answers
SOURCE: I have a pride victory xl8. Problem - was running
All scooters have a protection system built in to prevent burning up the motor, and the user, should the scooter overheat. It sounds like yours overheated. If the temp. outside was warm to hot, and your weight is near the weight limit for the scooter, and you are taxing the motors over a hill, or unstable terrain, then the scooter goes into "limp home mode", or just enough to get you a bit aways, and then it will turn off. After a few minutes to cool off, it will go again, but shut down fairly quickly because it takes a spell to let the whole transaxle-motor assembly to get cool.
Check your weight, and anything else you may be carrying with you on the scooter. Check the terrain, and incline you are going against. Throttle down for all these occassions. If you overloaded the system at some point, then you may have overheated the brushes. Remove them (2) with a standard screwdriver and see if the copper coil is still flexible and springy. If not, replace it/them.
The damage may already be done, so it may need a new motor/transaxle assembly. An expensive proposition I'm afraid.
Posted on Jul 09, 2009
Will
  • 25 Answers
SOURCE: I own a pride victory scooter that stopped
possible blown fuse or breaker needs to be reset.
Posted on Sep 15, 2009
littleone121
  • 23 Answers
SOURCE: i have a old pride victory 3 scooter working well
It is best to let it charge at least over night, longer if it hasn't been used for a while. It is also good to give them a long workout (Don't completely flatten them though) at least occaisionally. If they get regular and thorough use they will last longer, but extra weight like shopping, or lots of steepish paths will flatten them a lot faster. They are only supposed to last a couple of years, but will go longer if you look after them.
One of the most important things is to find a supplier/repairman you can trust. These are, after all your legs or mode of transport you are talking about.
Posted on May 06, 2010
Victory pride 2002 won't work?
hi Wendy it sounds like the batteries are so low that they can't even power the horn ?
check the batteries connection and the reset fuse situated at the rear .
regards
Rob
www.gewizrepairs.co.uk
Feb 18, 2017 | Pride Health & Beauty
Where do i find a repair manual for victory 9 scooter
I've never worked on one, but I would remove the battery, and turn the scooter over to see if anything is accessible from underneath. The controller could've burned up. With battery out, check continuity to see where the open is. I doubt it has a computer, probably a just the control panel a speed varistor, and controllers. http://www.monsterscooterparts.com/victory9.html
Manual: http://manuals.monsterscooterparts.com/mobility/Pride/manual-pride-victory-10.pdf
Nov 02, 2015 | Pride Victory 9 4-Wheel
Why does the Victory 4 scooter not move. It worked fine for 20 minutes. I shut it off, then when I tried to ride again it would not go. No sounds. Battery is charged and light and horn works.
hi, there can be a number of reasons for this, from a controller fault to a weak pair of batteries to a brake that is breaking down..
Please contact me so i can advise further...
Regards
Rob
Jul 06, 2014 | Pride Electric Wheelchair, Scooter, Power...
My pride mobility victory scooter will not charge
You must charge each battery individually with an automotive NON automatic style battery charger until each battery has at least 10 bolts each. The scooter charger cannot pull up a battery with less than 10 volts.
Jan 14, 2014 | Pride New Mobility Victory XL 4 Wheel...
Pride colt . fully charged batteries but no power to lights indicators or drive
hi, okay have you checked the fuses located on the tiller stem normally located under a black plastic cover ?
Your batteries may be fully charged but the voltage is not enough to power up the controller, sigh of a dodgy charger ? , bad batteries ? ? check the battery voltage , should be at least 24volts
The horn will work as it bypasses the controller logic.
Regards
Jan 20, 2013 | Pride Health & Beauty
1991 ford 250 horn doesn't work can't figure out
First, hook a test light to the power wire on the horn, push the horn button, and see if you have power there. If you have power, the problem is the horn itself. Maybe even run a jumper wire to the horn, and see if it will blow. Sometimes with these older trucks, it just as easy to change the whole steering column as it is to find the problem. (if you can get a column from an auto wrecker cheap) It will likely be a broken wire in the column somewhere, ususally near where it tilts.
Mar 14, 2010 | 1991 Ford F250
Rally 4. The steering seems to be stiff or tight.
hi,
ok now carefull tip the scooter onto one side, look at where the steering column attachs to the main frame, it's here you should find a bearing type collar, now you need to losen this and lubricate with a light gears, best to use a waterproof gease then tighting the collar up but
not too much otherwise your steering will again become tight.
Regards
GeWiz.
Feb 15, 2010 | Pride New Mobility Rally 4 Wheel Scooter
Pride New Mobility Victory XL 4 Wheel Scooter Logo
70 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
