Hello, I'm trying to import pictures from Nikon D3100 to my pc but get "access denied" when the camera starts to import.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer or Picasa.
SOURCE: How do I import pictures from my Nikon Coolpix
You can either connect the camera to the computer using the supplied USB cable, or remove the SD card from the camera and insert it into a card reader attached to the computer. The card reader is the preferred scheme, as it does not drain the camera's battery.
Yes and probably.
There apparently is damage to either the lens or the camera, most likely the camera. Though without being able to see any pictures damage to the lens is also possible.
If you can't see the menu when you press the MENU button then the damage may be restricted to the LCD screen. If the photos are black when viewed on a computer then the damage may involve the sensor. Without having an authorized Nikon repair shop take a look at it, it's impossible to know just what is damaged. And without knowing that, it's impossible to tell whether it can be fixed, and how much it would cost.
SOURCE: NIKON D3100 zoom problem
The D3100 doesn't have digital zoom capabilities. The zoom range depends on the lens you have fitted on. The 5.6 sounds like the aperture. The maximum aperture also depends on the lens.
The S3100 does have digital zoom capabilities. Is this the camera you're referring to? Or are you confusing the specs of the two cameras?
SOURCE: Can't import photos from Nikon D3100
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Picasa or any other photo cataloging program.
