Wont load past the Win XP Start screen. ive tried the BIOS update and it was unsucessful. Please help
Seems to be a bad driver or damaged boot.
If the computer shuts down and restarts check CPU fan and blow dust out from heat sink, CPU may be overheating.
Otherwise, use the recovery disk to repair, or the installation CD and do the system repair. Or from repair disk, if your computer worked fine before, Restore To a Previous setting.
SOURCE: How to change the Bios Boot on a HP Pavilian a141On
Go into the system BIOS when the desktop boots (usually by pressing del or F10) Go to the boot options tab and follow the instructions to adjust the order of the disks. F10 to save and exit - it should now boot to the required disk
SOURCE: hp pavilion a1220n shuts dwn after loading hp8500 pr drv xpsp3 os
If you can boot into safe mode, then once in safe mode open system restore and then restore to a couple days prior to the install of the hp drivers. This should fix the problem. If you need to know how to get into system restore let me know your operating system (Vista or XP)
SOURCE: I have recently recieved an HP Compaq DC7100 from
you may need to reformat the hard drive first before installing the XP.
SOURCE: trying to boot and change bios start up for compaq d530 sff
Unplug the case from the power, open the cover and try to locate on the motherboard a small round battery (a little bigger that the one at the electronic watches) TAKE CARE THAT THE TOWER IS UNPLUGGED FROM THE MAINS. Very carefully remove the batery and wait 1-2 minutes. After that insert the battery back, close the case, plug the tower and start the pc. It will boot at the default bios settings, without passwords but you have to make the settings again (date, boot order e.t.c.)
In case of a problem post back.
Stelios.
SOURCE: i have a compaq d530
Click here to go to HP's Driver page you can type in the model of your computer to download the drivers then transfer the driver files with a CD or USB Drive to install them on the HP tower. This should get all the components like Ethernet/ sound/ and video back to normal :) Hope this helps. Best of luck to you :)
