THE LIGHTS DO NOT WORK
Is the power supply cord unplugged?
Plug into a grounded 3 prong outlet.
TRY THIS
Is a light bulb loose in the socket?
Turn the refrigerator or freezer control to OFF. Disconnect the refrigerator from the electrical supply. Gently remove the bulb and reinsert. Then reconnect the refrigerator to the electrical supply and reset the control.
Is a light bulb burned out?
Replace with an appliance bulb of the same wattage, size, and shape. See the “Changing the Light Bulbs” section in your
May be the light switch or try this unplug refrigerator on screw bulb look in the socket there is a flat side in it the center get a flat screw deiver pull it up a little put back bulb plug unit if it dont light change switch
