Thanks for your assistance, Mark. I don't have a manual, however, so I don't know where the child lock button might be. I also read the other solution up here, I don't know where the buttons referred to are located. I don't see any door switches, just the lock sticking out of the oven.Thanks for your assistance, Mark. I don't have a manual, however, so I don't know where the child lock button might be. I also read the other solution up here, I don't know where the buttons referred to are located. I don't see any door switches, just the lock sticking out of the oven.
I had the same problem. Got the lever on the self cleaning oven to unlock which was great, but now the light switch is stuck pressed in? How can I depress the light switch inside the door? It's stuck-thanks I had the same problem. Got the lever on the self cleaning oven to unlock which was great, but now the light switch is stuck pressed in? How can I depress the light switch inside the door? It's stuck-thanks
You can't post conmments that contain an email address.
Re: Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know. Good luck!
Try pressing and holding down the child lock button the locklight should go out and the door unlock on some frigidaires the clid lock out locks the door to
On most of these ovens, you can either unplug the unit or flip the breaker from the main and keep it off for ten minutes, then either plugs it back in or turn it back on, and then hit and hold the start/cancel button on the control board for twenty seconds. Yu should hear a beep and then you should see the display light up and ask for you to set the time. If it does this, then the reset has worked. If so, put the oven into a self clean cycle and hit start, listen for the machine to come on, and about a minute later cancel the cycle and see if the door unlocks. If that doesn't work, you may have a bad door lock assembly and you will be forced to manually unlock the door.
To manually unlock the door, stick a screwdriver or heavy wire coat hanger in between the door oven and the door lock and see if you can disengage the door lock. If you manage to get the door open, leave the door open and put the oven into another self clean cycle. If after hitting the start button to activate the self clean cycle, you notice the door lock either not moving or getting stuck closed again you will need a new door lock assembly. If after hitting the start button, the door lock seems to be working fine, the door lock had probably shorted out during the cleaning cycle and looks to be okay now.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
Program the oven to self-clean.
Wait 20 seconds.
Cancel self-clean.
Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
Remove the oven racks.
Set your oven control to "Clean."
Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock
Thanks for using fixya.
If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
While you hold the door jamb switch in this position, complete the following steps.
Press the Clean pad, wait 10 seconds.
When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
Wait 10 seconds for the display to clear.
The door should unlock and there should not be a need for service.
Manual Switch
Press the Clean pad.
Close the door.
Slide the latch to lock the door.
Hit the cancel button immediately.
Unlock the door.
Range - "LOC DOOR" flashes in the display
Motorized Switch
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!$%!!!%!%
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door. Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
Door lock motor has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch motors, sensor probes and even the electronic controls can be destroyed by this operation. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. Sometimes bending a coat hangar into a hook and sliding from the right side into the lock you can unlock the door.
