Sylvania 22" flat screen tv model LC220SS1 picture on screen was coming in fine then it changed to a colored pattern and that's all you see on screen now
SOURCE: I need to adjust the color on my Sylvania, model #
have you tried to call them, because apparently it 's a hard to find manual on the net.
National Customer Service and Sales Center: U.S.A.
(For lighting products only)
General Lighting: 1-800-LIGHTBULB (1-800-544-4828)
Automotive Lighting: 1-800-347-3420
Electronic Control Systems (ECS): 1-800-654-0089
Consumer Products: 1-800-842-7010
Industrial & Commercial: 1-800-255-5042
Special Lamps & Markets: 1-888-677-2627
National Customer Service and Sales Centre: Canada
Industrial & Commercial: 1-800-263-2852
Consumer Products: 1-800-720-2852
Automotive: 1-800-265-2852
Special Lamps & Markets: 1-800-265-2852
Fax (local): 905-673-1012
Fax (long distance): 1-800-667-6772
SOURCE: I need a manual for
Here's the link to the manual.
http://funaiport.com/upload/SYLVANIA/Manual/LC220SS1_OM.PDF
I hope this helps. Bobya.
SOURCE: I have an Sylvania LC220ss1 flat panel tv after
Does this problem happen in all inputs of tv like watching tv programs or dvd movie etc?
Thanks.
SOURCE: i have a sylvania 20'' edtv no tuner or picture from cable
Does the set have any audio/video jacks on the back? Have you tried hooking to those?
If the tuner is bad cable can be hooked via a box or even using a old vcr to the rear jacks===switching to that input and bypass the tv tuner.
It will also tell you if problem is with the tuner.
Let me know if you have questions.
SOURCE: Damaged fuses to turn it the TV is of little use sylvania 22' Lc220ss1
have you tried to replace the fuse? Most likely there is a short circuit on the front side of the power supply. If you have any electronics repair experience, I would check for a shorted diode, bridge rectifier, or switching mosfet. You may be better off replacing the power supply.
Hit menu on your remote - click on picture - scroll to color
If you need a copy of your owners manual please click here
