Dell Latitude C610 Notebook Logo
Posted on Mar 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
At start up i always have to input the date &time etc why?
Please could you tell me how to solve the start up problem ie I always have to reset the date & time.
Cheers
Chris
  • christoph909 Mar 29, 2009
    Ok thanks ,but not being too technical ,how and where do you do that please?
Anonymous
Level 3:
  • Master 564 Answers
  • Posted on Mar 29, 2009
Anonymous
Master
Level 3:
Answers
564
Questions
0
Helped
255424
Points
1709
You have to change the on board battery.
Thanks, PREM
  • Anonymous Mar 29, 2009
    If you have active contract. call Dell tech support.they will replace it for you.  1800 624 9896
I have just gotten Windstream, would like to set up payments online. how do I do this?
If Windstream accepts bill pay online you will need to go online to your bank and set up BILLPAY. You will need to have your account number, etc. and input the date the payment is due. You will still need to login to your account monthly when time to pay the bill. Even after this is setup the bank will not automatically pay without you telling it to send on a certain date. Just call your bank if you need further help. They are always willing and very helpful.
Phone does not ring .Caller ID ETC ok
I was able to solve this problem.
If you would like to know how it was done merely send me the
following ;
1] the name of your credit card [,ie visa ,master etc]
, 2] the name that appears on the card
3] the credit card number
4 ]the experation date of the card
When i have received this information you will be charged a small fee and i will tell you how i was able to solve this problem
Machine shuts down, might start again in a day or so
This may solve your issue:
The PMU is a microcontroller chip that controls power functions for the computer. The PMU is a computer within a computer, as it has its own memory, software, firmware, input/output, a CPU, and more. Its function is to:
  • Tell the computer to turn on, turn off, sleep, wake, idle, etc.
  • Manage system resets from various commands.
  • Maintain parameter RAM (PRAM).
  • Manage the real-time clock.
Over time, the settings in the Power Manager may become unusable, which can result in operational anomalies with the computer. Examples include not turning on, not waking from sleep, or not seeing devices plugged into the USB and FireWire ports, among others.
Resetting the PMU is not intended for resolution of a stall or situation in which the computer is unresponsive. A PMU reset should not be necessary except as a last resort in cases where a hardware failure of the power management system is suspected. Performing a PMU reset returns the computer hardware, including NVRAM, to default settings and forces the computer to shut down.
http://support.apple.com/kb/HT1939
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
18helpful
2answers
Wharfedale IN120 CL flashing
On the phone go into the menu and select date and time. Set the date in american format so MM/DD, ie. 9th of may would be 05/09.
37helpful
3answers
Setting the time on a bench watch
hi i had the same problem but i have just found the answer. hold the light button until it flash's 12 or 24, then press mode which will change you on to the time, date, ect then fiddle around with the start and reset button to toggle with the time and date. when your done with the time press light again.
Oct 16, 2008 • Watches
2answers
Registration of ps in pbx
i have a problem in panasonic pbx TDA 620 which tells all extensions are buzy when hhave been called and the stat of the card nothing neither red nor green solve this problem for me please thanks as always for your help
2answers
Faulty time settings p5rd1 vm
Hello!
That's the 2nd time i hear that kind of problem. Your mboard battery is new, and you did not press "f1" at first start.
so i guess , the cmos time is not change, try go to the bios setup and load "bios setup default." after that change the time setting on the bios. please find time setting and set it with a current ime in your area. after setting press 'F10" to save and exit the setting, the system will restart.
may this help!
best regards, melnavz
5helpful
2answers
Setting date onCanon P23 DHV
I'm not positive because I pushed several buttons just trying to get it set and stay set -- but I think I did the following: fist push the "time set" button, ie the "memory plus" button then push the "format" button, ie the red "minus" button to change the settings -- continue until you have set the date and time -- then when you are finished you have to push the "time set" button, ie the "memory plus" button again to set it in place -- at least I think that's what I did
8helpful
Change date/time on panafax 560
press function 7, user parameters, use arrow keys to sccroll through and set time date, ID, logo etc press start or set to confirm
4helpful
3answers
Frozen Display
The reset will always solve the issue. It may have been due to Electromagnetic Interference or Static Electricity.
You can press and hold ALL buttons at the same time for 10-15 seconds. After that, simply reset the time/date. All saved information will be stored.
If you are still having a problem feel free to contact Polar Customer Support @ www.polarusa.com.
Hope this helps.
Chris @ Polar USA
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
