Refrigerators Logo
Posted on Mar 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Manual Defrost Function & User Guide Search
I just purchased a new Danby DSC326BSL 3.1 cubic foot refrigerator/freezer - a user's guide was not included in the box. My question is how does the manual defrost function work, please? Is there a user's guide book available & where would I find it?
Thanks
John Tripp
Level 3:
  • Refrigerators Master 4,656 Answers
  • Posted on Mar 29, 2009
John Tripp
Level 3:
Answers
4656
Questions
Helped
1677632
Points
14883
Here is a link to a users guide. May not be same as you model but will work to help answer your questions, Thanks, Sea Breeze
http://www.coolerstores.com/images_templ/danby-dcf401w.pdf
tip
Seven Rules for Replacing a Refrigerator
Here are seven rules of thumb that can keep your purchase of a replacement refrigerator from becoming a continuing drain on your pocketbook:
1) Don't buy a refrigerator bigger than you need. One rule is to choose a model that has 10 cubic feet of food storage for a family of two and then add an extra cubic foot for each additional person in the household. The freezer should be 40 to 45 percent as large as the food storage section. Thus a family of 4 will want to pick a model that is between16.5 and 17.5 cubic feet, and a family of 6 might choose a model that is about 20 cubic feet.
2) Side-by-side refrigerator/freezers use more energy than units with the freezer above or below the fresh food compartment. Side-by-sides also take up more space for the same storage volume.
3) Through-the-door features, like cold water or automatic ice dispensers, impose as much as a 20 percent penalty in increased electricity usage as compared to similar models without these extras.
4) Manual defrost models use less energy than automatic defrost units, consuming as much as one-third less. However, you should defrost the freezer when 1/4 inch of frost has accumulated.
5) Two refrigerators use more electricity than a single large refrigerator with equivalent storage space. And it is never a good idea to keep a half empty "his" refrigerator in the garage with beer and soda, while a "hers" refrigerator is in the kitchen with room to spare.
6) Don't let an old, inefficient refrigerator pass onto the used appliance market - recycle it for parts only. If your old refrigerator earns a negative investment return for you, it won't reward a family that must pay $50 or $80 on top of the hefty energy bills.
7)) Look for the Energy Star label. It is a quick and easy way to avoid paying for a mistake with each month's electricity bill.
on Sep 21, 2010 • Refrigerators
tip
What to Look For in a Refrigerator
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Refrigerator Buying Guide
Buying a refrigerator is an issue that is too complicated to many types of refrigerators that are available today. The function of refrigerator has actually gone beyond the basic of keeping food cooled and chilled. There are features that are equipped in most advanced refrigerators now. Therefore, choosing the right one that suits your family will take some time and require some basic knowledge on refrigerators. Here are a couple of things that you need to look out when buying a refrigerator.
The first thing that you need to decide is the capacity when it comes to buying a refrigerator. The rule of thumb here is to go with the general guideline where a family of two needs at least 10 cubic feet of fresh foot storage. You can add extra cubic feet for additional person in your family. Therefore, an 18-cubic-foot refrigerator is the smallest unit that you should get for a couple. A family of four needs at least a 22-cubic-foot refrigerator. Of course, if you can afford bigger refrigerator, the better it is. But be reminded that it takes more electricity to operate a bigger refrigerator which leads to higher electricity bill.
Adding to the capacity, the size of the refrigerator is also important. The size can sometimes be a limiting factor in determining the refrigerator that you want to buy. In a case of a family that needs a 22-cubic-foot refrigerator but the space in your kitchen can only accommodate an 18-cubic-foot unit. If that is the case, you should probably make some space by removing certain items in the kitchen to fit the 22-cubit-foot refrigerator. Or else you can consider a side by side refrigerator if space is a concern. A side by side refrigerator consists of a freezer that is adjacent to the refrigerator. The advantage of side by side refrigerator is that it needs less door clearance which makes it ideal for a narrow kitchen.
Other factor to consider when buying a refrigerator is to select the type that suits your living style. There are several types of popular refrigerators in the market ranging from the commonly used top freezer, bottom freezer, side by side to the exotic French door unit. The top freezer is the most commonly seen refrigerator due to its affordability and simple design. Besides, the top freezer is also the one that has the least problem. Therefore, reliability issue seldom exists in top freezer refrigerator.
The bottom freezer model is equally comparable to top freezer but it's slightly more expensive. The advantage of bottom freezer lies in the convenience where more frequently used storages are placed at eye level. It's claimed that people with back pain problem should use the bottom freezer refrigerator to alleviate the back pain since you don't have to bend to access the food in the refrigerator.However, people will sometimes accommodate a side by side refrigerator in their kitchen. One of the reasons behind it is that, these refrigerators are often equipped with plenty of extra sophisticated features that offer loads of conveniences to its users. Other reason might be due to the exotic look of these types of refrigerators instead of the normal top and bottom freezer units.
Note, if you planned to get a refrigerator that is more than 22 cubic feet in capacity, consider one which is Energy Star qualified. An Energy Star qualified refrigerator means energy efficiency. An energy efficient refrigerator is very conservative in terms of electricity usage and it might help you to save some utility cost. One thing for sure is that you might be able to get rebates of up to a few hundred dollars for trading in your old refrigerator with a new Energy Star qualified model. A lot of utilities companies and even the local government do offer this kind of rebates. Therefore, do enquire the sales persons when you are in the stores.
All in all, buying a refrigerator is not that of a difficult task. All you need is some practice and some basic knowledge in refrigerator. Please whenever you really want to buy a refrigerator , make sure that you have done some research on the model that you are looking for ,the things that you want to look out and the cost of purchasing and the features so that when you are at the store, you will really go for your choice from your re-search.
on Feb 26, 2010 • Refrigerators
1helpful
How can I adjust an upright freezer door ?
Hello there,
It is always the feet and their adjustment and floor must be level
From the user guide it says
;The freezer must have all bottom corners resting firmly on
a solid floor. The floor must be strong enough to support
a fully loaded freezer.
NOTE:It is VERY MPORTANT for your freezer to be level in order to function properly. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems.
To level Upright Models:
After discarding crating screws and wood base, use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, half a bubble higher, so that the door closes easily when left halfway open. ;
User guide here
http://crosley.com/assets/product/1707/useCareGuide.pdf
Brought a 3 cubic foot freezer that will not run
call Danby or go back to where you brought will exchange
Need Freezer gasket for 20 cubic foot freezer upright Model #WFF20Z
I would suggest you check with a local appliance parts warehouse. They will also have a service manual that you can purchase that will guide you.
Danby DFF8803W freezer keeps freezing up. What causes this?
Some models are a manual defrost. That meant every 3-4 weeks you must unplug it and let it defrost. These types usually have no fan in the freezer, instead it's a cold plate. If there is a fan in your freezer section it should automatically defrost. You might have a bad defrost clock, or a bad defrost heater.
8helpful
2answers
How big inside (cubic ft.) is the Roper refridgerator
20.9 cubic feet for model # RT21AKXKQ
14 cubic feet for model number RT14BKXKQ05
2helpful
Please help with (User Guide)
You can obtain an english Camera User Guide and a Software User Guide from the Canon website. If you want to get a hard copy you will need to contact your local Canon Service Centre and ask if they can order one in for you to purchase.
Link to manuals...
http://support-au.canon.com.au/EN/search?canonsearch=1&lang=EN&category=Cameras&series=Digital+Compact+Cameras&model=DIGITAL+IXUS+110+IS&menu=Manual
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
