I'm in the "press dot function". The problem is that I have only 1 or 2 seconds to press the dot beacause after I can't press on it anymore... the dot stay on the screen, but when I press on it, nothing happen. I've try to press very fast on every dot but it frese after 5-6 button... How can I solve this problem ???
SOURCE: Unit turns on for 5 seconds then shuts off.
I charged the unit and now it works fine. Plug into computer and charge for a while and the unit should work fine.
SOURCE: The screen of my Garmin
I think that you will have to make a total reset in this unit to make it functional ..but keep in mind that this will erase all data on it and you will have to reconfigure it again ..
Here is the procedure ..I left it like it was in the tutorial cause one never knows exactly how it will behave ..and they have more than one way to do that ..I suggest that the last one will work ..
In the Quick Start Manual of Garmin Nuvi 255w GPS, it stated that you
can reset the unit by pressing the RESET button at its bottom. However,
the RESET button is not found in my Nuvi 255w.
Additional
information in the Owner's Manual stated that if RESET button is not
found, slide the POWER key and hold it for more than 8 seconds will do
the same, but I found out doing so will go to the touch screen
calibration utility instead.
Another section in the Owner's
Manual under the title "Clearing User Data" stated that holding your
finger on the lower-right corner of the screen while turning on the unit
and keeping the finger pressed until a message appear, that will allow
you to delete all user-entered information.
I tried it and a
message window pops up asking about "Do you really want to erase all
user data?". There are 2 buttons to select, Yes or No. If you want to
try this, make sure you've backup the data in your unit before answering
to Yes.
SOURCE: I followed the steps for
The
white screen has a "Press Dot" that you need to touch when prompted.
The screen keeps displaying "Press Dots" that you need to touch until
the message "Calibration Complete" appears. This process recalibrates
the touchscreen so that it responds accurately to your touch commands.
SOURCE: my gps is froze on a screen that just says press
If you have questions feel free to reply to this solution.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
SOURCE: when i turn my garmin on it says loading maps then
You should use web updater. this is how.
- Download and install Web Updater
- connect your Nuvi 255W to your computer using the Nuvi's USB cable.
- Run Web Updater.
- Choose your Nuvi 255W from the device list on Web Updater.
- Allow Web Updater to search for software upgrades.
- Select "Yes" when prompted to download and install the updates to your Nuvi 255W.
if above doesn't assist, please follow this method.
Thanks for using fixya.
