Im unable to acesses the tv with universal remote can you help me out with the code to be entered for my tv model and to figure out the code to operate
SOURCE: Universal Remote control code on Sharp 13H-M60
Your remote should have come with a sheet of paper with all the codes on it for different TV's, VCR's, , etc.
SOURCE: Accessing Menu Sharp TV
I have a Sharp TV model 27F-S40 and also do not have the remote. I need to access the menu to change color, sound, etc.
Can I access the menu thru the channel or volume buttons on the face of the tv?
Bob
SOURCE: not sure if converter box is needed???
Hello Ann, I will try to help you, well if your for sure about the Manufactur date on the T.V., then yes you will need a digital converter box, also it is suggested to have an outdoor UHF/VHF antenna with coax to attach to your converter box, the old rabbit ears aren't suggested. I hope this helps in getting you prepared for Feb. 19, 2009 when all T.V. stations broadcasting will convert to the new signal. Thank You and Have great day.
SOURCE: How can I still use this TV?
find another TV, VCR (many around now), or other cable using device and exchange - 7 or so screws on back of tv come right off and expose lower interface where cable jack is. remove wires, solder salvaged unit in and it works.... Be careful when removing back of tv - you can pull other wires when doing so.
