It is not sending liquid from upper tank to floor, but it does **** up liquid off the floor if I pour it there?
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
My FloorMate H3012-020 developed the same problem after
about 2 years. I tested the flow of liquid through the tubing and
distributor by placing a small amount of liquid in the opening under the
solution tank and making sure it drained when the solution trigger was pulled. Since the liquid did drain all the way to the
brushes, it was apparent that the solution was not leaving the tank. In the center of the opening that receives
the solution under the tank (round opening with rubber seal) there is a plastic
pin that is supposed to push into the valve on the solution tank and open it
sufficiently for liquid to pass through the valve. Since the plastic pin has not changed in
length, I assumed that the rubber plunger in the bottom of the solution tank
may be the problem. This rubber piece
does not seem to be replaceable. Since I
am very cheap, I am unwilling to buy a $30.00 solution tank to get a $.25
rubber plunger for this valve. My
solution was to make the plastic pin a little bit longer. I did this by drilling a very tiny hole in
the top of the pin and installing a very small screw which allows me to adjust
the distance that the pin pushes up into the valve on the tank. I adjusted the screw almost all the way down
and turned it up a little at a time until liquid once again flowed to the
brushes. I have only used the machine
once since this modification but it seems to dispense liquid very well now.
A word of warning, if
you break or damage the pin in the process of this modification, the control
valve assembly will not work and it does not appear to be available as a
replacement part. If you are not
confident in your ability to make the modification, then a $30.00 solution tank
is cheaper than a new machine.
