Good day, I have a Thomson 46RH44E ICC19(100hz) Projection tv, while watching it, the picture dissapeared and now the power light flicks red on and of, is there something that I can have done to repair it, I just love this tv and can't go without it, do I need to replace anything. Thank You and regards Estelle . I reside in South Africa, Gauteng
SOURCE: TVDOWNLOAD FREE REPAIR MANUEL FOR RCA HD65W2OJX1 THOMSON MULTIMEDIA
· http://www.eserviceinfo.com/most_popular/list_5800.html
· https://www.manualsparadise.com/Sho...model=M31429247
· https://www.completeservicemanuals.com/panasonic/digital-camera/lumix-dmc-fz5-service-manual/prod_86.html
· http://www.user-service-manuals.com/Sony/UP.shtml
· http://www.schematicsforfree.com/
SOURCE: replacement lamp for rear projection tv
go to mcm electronics.
good luck
please mark the post with a fixya
SOURCE: thomson DV3 digital terrestrial recorder
this recorder is constantly getting bad reviews, I think it is unfair because mine does the job, however this problem occured heres what you do.
turn off at the mains and wait 20secs turn back on and hold the standby button untill a light appears.
in sequence up down left right menu ok press the buttons on the front of the box wait 60 seconds and the normal red light will appear turn on box and there you go.
Good Luck further issues visit www.topuptv.com WARNING- doing this procedure will swipe your library but i think it is the only solution
SOURCE: Thomson Scenium 52''Rear Projection TV set -
you have a laser that has gone out blue or green take the face off and see which of the colors you need you can still find lasers on ebay if you need one but it will require someone with a little expertise to replace them. if this is not for you then its time for a new TV this is probably the best option its more expensive to fix in most cases than to replace..........I hope this helps
Hi, I need assistance re tuning my TV for the VCR. I am not able able to get the two solid test lines. My TV is a Sansui SV2790NICAM and the VCR an Orion.
Please help!!
Mike, C.T.
