Mitsubishi WD-60638 DLP TV Logo
Anonymous Posted on Jul 11, 2013
Red statis light - Mitsubishi WD-60638 DLP TV
Anonymous
Level 3:
Top Expert:
  • Mitsubishi Master 14,553 Answers
  • Posted on Jul 20, 2013
Anonymous
Mitsubishi Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718088
Points
48227
These sets have a specific blink or error code, it is also possible to call up a error code even if set does not come on.
TV WILL NOT TURN ON AND RED STATIS LIGHT IS ON NO CODES ARE SHOWN. WHAT DO I DO?
If the red indicator light on the front of your HDTV is glowing a solid red, you should first unplug the AC cord from the wall power outlet and wait for 60 seconds before reapplying power to the HDTV.
After you turn the TV on, if it doesn't power up, try holding the power button down for at least 8 seconds. That's supposed to force a system reset. If your model has a system reset button, use that instead. Press the reset button for about 20 seconds...release it and press it again for 20 seconds, release it again and the led will blink just for a minute or two. You should now be able to turn the TV on.
If after several attempts, the HDTV has not fully powered on and the LED on the front of the HDTV is still glowing solid red, you may want to reseat the lamp.
If reseating the lamp has not resolved the issue then your next step is to order a replacement lamp. Keep in mind that some off-brand lamps may only last a few weeks, so replacing a relatively new off-brand lamp may unfortunately be necessary.
Red statis light on
replace lamp if lamp is ok replace color wheel
Right half of screen out
This is a problem in the processing of the video signal, cheaper to replace the DVD player.
My statis code reads #33 which limit flame or roll out switch is open i dont know where to locate a roll out switch . i just never work on this heating unit
The flame rollout switch should be located in combustion chamber directly above the burners.Most of them have a red reset button in the center. Check to see if it will stay in when you push in on it. If not then replace it. Hope this helps you.Thank you.
The red light is statying on the printer
What is the brand and exact model number of printer?.In most of the printer brands.The red light stays on, if any of the cartridge is empty or got faulty.Or if there is no paper or paper is jammed in the printer.Check out.Keep updated with details.Thanks.Helpmech.
What does it mean when the red light is on for the statis and the screen is black. I have the tv off but when I turn it on the screen is black.
That means the set has shutdown for protection. Hold menu and device buttons both in together for five seconds on the set then count the blink sequence and let me know what the blink sequence was.
Status light stays red no tv no power light
TV requires service. but try to reset it by pressing system reset
3answers
Speakers/3 color codes
CONECTARE STATIE AMPLIFICARE
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
