You need to go to BIOS and enable active key method:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=c02035108
SOURCE: My FN+F6 doesnt keep my screen on the laptop open
I think you're trying to output the screen to external monitor right ? So when you press Fn+F6 this will output to external monitor only but if you do it again it will output to both (External and you LCD) and if you repeat the step again you're back to normal.
goodluck,takecare.
Change the settings from the display settings panel. (Right click on the desktop and go to display settings)
You should see 2 monitors graphically represented there.
You can make the monitor that is greyed out active by right clicking on the monitor, and selecting active.
SOURCE: mouse frozen in screen center
i presume you still have the manual for that computer.... i believe the newer computers allow you to shut off the touch pad... look for the key combination for that
SOURCE: power button is on but screen is blank
try using Fn+F3 or F2.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
F1 - Security System
Press and hold the "Fn" key on the lower left-hand corner of your Toshiba keyboard.
Press the "F1" key to activate the security system.
Your laptop's screen will go blank so others can't see what you are working on or accessing.
No Fix, No Fee. Same Day or Free. We Come To You - 1300 723 628
www.thepcdoctor.com.au/melbourne
Press any key or touch the touchpad to exit the security mode.
F2 - Power Save Mode
Press and hold the "Fn" key.
5
Press the "F2" key to activate the Power Save mode and make changes to how your laptop handles operating on battery or AC power.
6
Press "Fn" and the "F2" key again to exit the power save mode.
F3 - Standby Mode
7
8
Press the "F3" key to place your laptop in Standby mode.
The Standby dialog box will appear.
9
Verify you want to enter Standby mode. Press the power button on your Toshiba laptop to exit Standby mode.
F4 - Hibernation Mode
10
11
Press the "F4" key to activate the Hibernation mode and save whatever documents and files that are open to your hard drive.
12
Verify you want to enter Hibernation mode. Press the power button on your Toshiba laptop to exit Hibernation mode.
F5 - Active Display Device/F6 and F7 - Toshiba LCD Screen Brightness
13
14
Press the "F5" key to change your laptop's active display device from the laptop screen to an external monitor.
15
Click on the display configuration you want: displaying on both the laptop and external monitor; only on the laptop; only on the external monitor; or a specific screen resolution.
16
Press and hold "Fn" and "F5" to accept the new display settings. Press and hold "Fn" and "F5" again to return to your laptop's display only.
17
18
Press the "F6" key to decrease your laptop's screen brightness. Press the "F7" key to increase the brightness.
F8 - Wireless Connection/Bluetooth
19
20
Press the "F8" key to select the wireless Internet or Bluetooth connection you want to use.
21
Press and hold "Fn" and "F8" to make your selection. Release the keys to confirm your selection.
F9 - Touchpad Control
22
23
Press the "F9" key to enable your laptop's touchpad.
24
Press and hold "Fn" and "F9" again to disable the touchpad.
F10 and F11 - Numeric Keypad/F12 - Scroll Lock
25
26
Press the "F10" key to enable your Toshiba laptop's numeric keypad.
27
Press and hold "Fn" and "F11" to enable the cursor control keys on the numeric keypad.
28
Press and hold the "Fn" and "F10" or "F11" key to disable the numeric keypad or cursor control keys.
29
30
Press the "F12" key to lock your cursor on a specific line of text. Press and hold "Fn" and "F12" to turn scroll lock off.
hope this helps
