The copier started printing blank copies just yesterday the toner is full, Drum is fine i have tested it on another other copier and it is working thanks.
SOURCE: Canon NP-4050 printing almost completely black pages
This problem appears to be that the scanlamp cable has fatigued and become open-circuit. This can be checked by selecting A3 and pressing the START button while having the lid up. Watch to see if the light stays on all the way through the forward pass of scan cycle, it can be intermittent. Make sure that the machine is unplugged before attempting to replace the cable.The drum is definitely on its way out at that amount of copies, but can be made to last a fair bit longer with some fine-tuning.
SOURCE: Actually a Canon PC-65, problem follow-up
canon older model PC_6RE problem: the third copy and byond, streeks appear on the left side, progreesivly get worse on each additional copy, a wait of about 2,hours, then the 1st copy is clear again, any solution for this?
SOURCE: re: canon ir3100cn E000020-0081
I just spent 20 min typing a detailed post why the e225 is already fixed and the e020-0081 is common and means the drumm patch sensor is dirty and then the web site erased it. Grr.
The drum patch sensor shines down at about the 11 o'clock position halfway down the drum. Remove the drum taking care not to scratch it or the transfer belt and clean the sensor window.
If the problem re-occurs then you may need new developer units.
SOURCE: hi ya have a canon ir2010
Looks like a worn out or dirty drum unit. I believe you need a service center to replace this drum or service it.
How to Connect Dell b1165nfw Wireless with Wireless Network?https://connectprinterwifi.com/how-to-se...
HP OfficeJet Pro 8210 Printer Offlinehttps://printerisoffline.com/hp-officeje...
How To Fix QuickBooks Error 102 Code?https://quickerrorfix.com/how-to-fix-qui...
How to fix Canon mx920 Printer Offline Errorhttps://start-ijsetup.com/canon-mx920-pr...
