Did you remove the base from the back? If so, there are two stating slots at the bottom of the screen. A fine blade screwdriver will release these tabs. Once down, the front bezel will pull away but you'll need a flat blade screwdriver (preferably made out of plastic). Slide this screwdriver between the front bezel and the screen frame which is metal. Don't allow the driver to get next to the screen because it will scratch easily. Using the driver you'll be able to pry away the bezel from the rear.
How you remove the base? I can get the bezel off around the screen, but not on the bottom.
