Question about RCA Televison & Video
Rca tv will not power on. no sound no picture
52inch hdtv. model # d52w26 will not power on. there's no sound or picture.
You need to call jerome at tth electronics in canton,ohio
330-371-9896 he will solve it for you.
Posted on May 30, 2009
6ya staff
SOURCE:
RCA D52W26 TV Powers on and has sound. It has no picture.
If this is an LCD TV, show a torch light on the screen from a safe distance. If you can see the picture, the back light is not getting on. You may have to call in a qualified service technician.
Aug 02, 2012 | RCA Televison & Video
Hi my name is Robert I have an rca 52inch tv model# d52w20byx1. The tv gets power no picture or sound. Can you give any suggestions
jaxff85,
I certainly can. I have a tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting which will walk you through the troubleshooting process and help you pinpoint the problem.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 28, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a rca 52inch hd52w56 power light on front of set is solid,then flashes ten times,then solid again for a minute. repeats. tv will not turn off or on. ???? screen not on,no picture,no sound,nothing??
DM power board have some dead capacitors.Some capacitors bulge up,best indicatoin it dead,some u must used a multimeter to test.U know how to use a soldering iron and solder?Change all the DM power board capacitors,should get power back to ur tv.Try website Tv repair World.com maybe still selling this refurbish DM power board.
Mar 25, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca hdtv 52inch will play fine then picture goes black but still has sound.. after a few mins.picture will come back on , and will play fine could last all day or may go out again in a few mins.
My tv is relatively new, but the bad thing is that I had an old; big screen tube type rca model; home theatre, that was heavier than a car, and it went out, due to the cracking and popping sound, off sometimes, and back on.
What is strange is the new tv now, the hdtv, light weight, about five years old, is doing the same thing. Actually, now, the power will not even come on. The lcd green light in the front goes on and off.
Take no offense, but I thought I would not have these problems anymore. What do you suggest?
Feb 16, 2010 | RCA HD52W59 HDTV Projection Television
RCA D52W26- 52 " rear projectio- 3d
try to inspect the convergerce power supply and the convergence output module for cold solder joints around the mos fets...i had seen many of them on the same condition.
Jan 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca 52 in projection t.v has problems powering up
Push and hold power button. If it cycles and blinks on/off in 3s or 9 times, it is a power problem. Replace the deflection board. Cost about 250.00
Jan 04, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green Screen, No Sound, Shuts off after 10 seconds
Almost certainly the green picture tube is shorted. This is a very expensive repair; probably not worth doing.
Apr 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture (fan& bulb do not come on) but there is sound
I have a RCA 52inch D52w136D, the power button blinks three times, but nothing happens no picture or sound
Nov 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52inch hdtv
Please replace STK392-110 quantity 02 in your tv to fix convergence problem.
Above said part is available here.
Regards,
Sep 27, 2008 | RCA HD52W59 HDTV Projection Television
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
Nov 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
243 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
