Its a maytag dryer model lde9360ace. Everything works it heats, spins, etc but the end of cycle buzzer will not shut off.
Follow this steps and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a
timed cycle say 30 minutes or so then time it. If in 30 minutes the
timer hasn't moved and the dryer is still on, the timer is bad and need replaced. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some
dryers have two heating elements and if one goes out the timer will not
advance if you use it on an automatic cycle but you will still feel heat
inside the tub. replace the heating elements
SOURCE: Kenmore Series 70 Dryer Buzzer won't stop buzzing - Model 110.96573220
SOURCE: Dryer heat shuts off after a few minutes.
replace the 2 black solenoids on the gas valve ..after heat up they sometimes will go bad and burner will not reignite even though the ignitor glows
SOURCE: Dryer not heating
It was a voltage problem with mine. My negative power supply at the dryer had come loose... which seems like a dangerous design flaw. I tighted all the 220V wires in the back, and it works perfect. The light bulb works now, but still flickers as the dryers is slightly bumped from unloading clothes. Hope this helps anyone else!
SOURCE: Kenmore Model 96573220 won't stop at end of cycle.
I figured out it was the start switch and took the switch apart and repaired the welded together contacts. Took only a few minutes.
