Dishwashers Logo
Tracey Tasker Posted on Jul 08, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How much salt do I put in ,,, and why won't it
ernesto cuadra
Level 3:
Top Expert:
  • Dishwashers Master 12,223 Answers
  • Posted on Jul 09, 2013
ernesto cuadra
Dishwashers Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4081125
Points
34431
Follow this steps and fix it. God bless you
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
1helpful
Intex Automatic Salt Water System For Above Ground Saltwater Pool won't turn on
Usualy if it is some years the ball bearing on the motor shaft are rusty and if you can desasemble and use a UD40 lubricant or similar it can be fixed, or replace the bearing. One more posible case is the starting capacitor if it replaced can run the motor again.
1helpful
Salt light won't go out in a Miele Dishwasher
As per other thread, descale machine with kettle descaler in the dispenser instead of powder, then run the machine through a cycle with nothing in the dispenser. The salt chamber sensor will eventually clear, but make sure you don't overfill with salt.
3answers
Why does my softner never use much salt?
That is hard to say Lewis. How much is not much? Salt usage depends on the frequency of regeneration. This is dependent on the water chemistry, usage (metered or time clock), salt dosage and the capacity of the water treatment system. I have customers that go through 280 lbs of salt per year and others that go through 150 per month. Some of these customers are very heavy water users, 2000+gallons of water per day in a private residence. While others won't use 2000 in a month with the same amount of people.
I would suggest you have the water tested to make sure it is soft. If it is then the system is OK. Although I would suggest that if you do not use much water to only fill the salt tank about 1/2 full to avoid mushing and/or bridging of salt in the tank.
RJ
My pool is cloudy and I added clarifier and it still won't clear. I checked the salt count and it's reading 1100 ppm. We have a 15 foot round 48 inch deep pool. I also shock the pool weekly...
1st... Your salt count should be at 3000 ppm... For your size pool, the start-up salt needed should be about 95 to 110 lbs..
2nd... Run your pump for 24 hrs without the chlorinator after you have reached the 3000 ppm to properly disolve the salt and use only "pool salt"
3rd... Set your pump at 12 hrs and your chlorinator at 10 to 11 of those hrs until you have reached the desired chlorine level.
4th.. After your pool water has cleared, within 2 to 3 days...clean your chlorinator electrolytic cell and adjust your time down to maintain the proper chlorine level..
Hope this helps and if it does, please rate and comment....
Good Luck!!!
Will Neff dishwashers work without salts and liquid?
While salts are not required, if you don't have water it won't clean your plates very good, and will also burn our your pumps.
1helpful
I don't have a problem, just a question. I recently purchased a home with a GE Smartwater softening system installed Model GXSF23Z01. What do I need to do to maintain this system. Does it require salt?...
Check the time of day, and make sure it's accuate. Reset if necessary. Add salt if it's low. It's always best to let the salt level run low (about 1-2") so it doesn't mush. Only add 80-100 lbs at a time for best results. This particular softener doesn't keep a water level in the tank, so you won't see any water in the salt area. If there is standing water in the salt area, that could mean it's not working the way it should. Here is a link to the owners manual. It's in PDF format
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=003674144.PDF
26helpful
3answers
Mistral super slushie maker user manual
omg..i jist got a minstral super slushie maker..and man it jist doesnt figure,cant make the slushies..how does it work,,put ice cubes and rock salt and lil water in the ice hole and turned on mix switch and then pored cordial in the back of lid,,all read from the instructions and let spin for 15 minutes,,and nothing three times,,dumb founded,wat the???
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
