I have a Hicense TL1700 that will only come on now and then--I think the power supply is bad--it has the kind that has a transformer--sometimes it will come on if you tap the transformer part--sometimes it just clicks on off on off--sometimes just the HICENSE word is on the screen and it will not come on! HELP SOMEONE!! I have a Hicense TL1700 that will only come on now and then--I think the power supply is bad--it has the kind that has a transformer--sometimes it will come on if you tap the transformer part--sometimes it just clicks on off on off--sometimes just the HICENSE word is on the screen and it will not come on! HELP SOMEONE!!
You can't post conmments that contain an email address.
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
10 blinks on KDP-57WS655 model no. is an error code for "High voltage protection". I can tell you exactly which part gone bad and assist you to fix it yourself. Click it here.
Jdvillanueva
Hi, TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front. Hope these info will help you. Thanks.
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.But if you don't hear any strange noises,tv is around 4000 hrs,2-3 yrs it could be time to replace the lamp.The lamp you need is 915B403001.Have a blessed one!
unplug the television...wait 10 seconds and then plug back in....if you listen carefully after 5-10 seconds you will hear a click sound (the same sound that you hear when you turn on or off) ...once you have heard it, turn the TV on again using the remote. Do not turn on until you hear the click. If this does not work, try again but turn the TV on again before you hear the click. I dont know why it happens but it is as if the TV gets confused as to whether its supposed to be on or off. Most of the time, the solution is to turn it on after the click so I would always try that first.
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
