I got a Canon ZR500 over Christmas. I've been using it often since then, but recently it has had a problem that prevents me from using it. Whenever a cassette is placed into the loader and it slides in, it pauses as if to read the tape, and then says "REMOVE THE CASSETTE" in red letters and ejects it. This happens with any cassette that we try. It will also refuse to close the cassette bay and keep closed, even when there is no tape in the camera. The motor closes the door, and then it beeps and reopens it again. What's going on?
If your camcorder experiences an error, you may be presented with a ?Remove the Cassette? message. There are several reasons that this message may appear, but it is essentially a safety warning that is designed to protect the camcorder and/or tape from damage. The camcorder?s tape drive mechanism is made up of many precision components that, once damaged, may cause further problems if the mechanism continues to operate. When a problem is detected the safety mechanism is activated. The ?Remove the Cassette? warning and the camcorder?s safety mode may be activated by a variety of conditions such as: 1. Condensation is detected ? If condensation is detected by the camcorder, the ?Remove the Cassette? warning may occur. 2. Component failure ? If an electrical or mechanical component in the camcorder fails, the safety mode may activate to prevent any further damage to the camcorder. 3. Sand or grit damage ? The camcorder?s tape drive mechanism consists of many tiny gears. Sand or grit can cause a gear to jam and stop turning. This will cause the camcorder's safety mode to activate. 4. Impact damage ? If a camcorder is accidentally dropped or bumped against a hard surface, it is possible that a misalignment of the tape drive mechanism may occur. 5. Liquid damage ? If either the camcorder or the tape is exposed to water or any other liquid, a variety of malfunctions may result. Please avoid this situation. 6. Improper videotape insertion ? If a tape is forced into the cassette compartment, or if the cassette compartment is pressed down while the tape is loading, damage may occur to the tape drive mechanism. Please refer to the User's Manual. 7. Damaged or defective tape ? If a tape becomes damaged, please discontinue its use. Operational Recovery Steps Depending on the conditions that caused this message to appear, it is possible that the camcorder operation may recover. Please follow these steps: 1. Eject the videotape Insert a new or known good videotape. If the message does not persist, it is possible that the tape was damaged. If the camcorder still displays the message with a new tape, please proceed to step 2. 2. If condensation had been detected causing the Remove the Cassette warning, remove the cassette, and allow at least one hour for the moisture to dry. If the "Remove the Cassette" message continues, the camcorder may require service. Please contact Canon USA's Tech Support Center at 1 (800) 828-4040. Technical support hours are Monday through Friday, 8:00am - 12:00 midnight; and Saturday 10:00am - 8:00pm (all times EST). Alternatively, if electronic support is preferred, please send your email to [email protected].
