"I have a GE 2800 dishwasher model GSD2800G07. When I hit start the drain pump/motor does not engage. After 3-4 seconds water starts to fill the tub. When I hit reset the pump solenoid starts to buzz loudly for 3-4 seconds and shuts off. Fan blades spin freely. Solenoid plunger moves freely. No apparent wiring issue. Thoughts?
SOURCE: dishwasher - no spray arm action
I also had this problem and it turned out to be a small piece of a drinking glass that had made it all the way to the chopper and wedged between the blade and the housing. I was able to do all of the work from inside the dishwasher without disconnecting anything.
I am almost certain that your problem is the fill solenoid.
If it does not work, there will be no water entering your machine.
I would either remove it and test it or just replace it at this point.
Tim
SOURCE: GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
SOURCE: kenmore elite not washing dishes
Sounds like the motor is stuck. If your careful you can unplug the dishwasher or turn the breaker off, take the bottom panel off and reach in with your finger and spin the motor assembly.
SOURCE: My GE Dishwasher GSD2030 fills with water, but
The problem is more than likely something is stuck in the prop. that helps to grind up foods so they can pass thru the pump. Remove your dish racks, take a small screw driver and gently pry the lock out that the sprayer sits in and pull the sprayer up and out. If it has a filter, remove the 1/4 in screw that holds it in and push the lock in and pull the filter up. You will notice 2 screws in a plastic strainer towards the back of the tub. Remove the strainer. You will then see where the water drains.Remove that strainer and feel down in the drain. you will feel the prop. Remove any foreign materials from the drain and from around the prop. Probably a piece of macaroni. lol . Make sure you turn off the breaker before starting any repairs.
