I have use this disc often but now when I go to brings up cards to select nothing is on the screen? Have I use it too much?
Good solution vallis! I have solved many of my disc reading errors this way. Now, i always try this first and it works 9/10. A good suggestion for future reference for you nannytojack is to make backup discs of all new programs and use the backup in a new labelled csse, and put the original away to keep it pure and safe!!! You can also try uninstalling the program and reinstalling it, as they can get corrupted files very occasionally and prevent proper reading.
Its possible that the disc has gotten too rough to be read right. Something you can try doing is making a copy of the disc if you have a CD burner. Sometimes the software that CD burners use are a little more sensitive than just the regular windows reading software. Make a copy of the disc then try using it like you did the orginal. Just be sure you keep the orginal copy, just in case.
yo tengo los disco originales, pero mi maquina se arrino y me la formatearon y cuando quise cargarlo me di cuenta que de estar guardado un poquito de las pista habia quedado pegada en la cubierta donde lo guardaba y no pude cargar el programa.
asi que me sientro triste por eso....sera que se puede hacer algo?
