I just recently purchased an air conditioner and I need some help with the installation. In the booklet it says that if you want continuous drainage that you need to have the continuous drainage hose out...
The model you have has an evaporator feature, that normally evaporates the left over condensation. However, there are times that the humidity level may be to high to handle all of the left over condensation. In which case, the pan would need to be drained. In most instances, a plastic low sided container would suffice. But, if you run the AC unit in a continual mode, there's a good chance not all the left over condensation would be evaporated.That's what the hose is for. Not sure why there are 2 of them. Generally there's only one. Anyway, the unit also will shut down automatically, if the pan gets full and needs to be emptied. It will not run until it's emptied. But, I caution you not always rely on that. Anything can go wrong when you're not at home.
Hope this helped you understand how the unit operates. If you have any more questions, call Danby's Customer Support Dept. The 800 number is in your Owner's Manual. They're good folks and will do what's necessary to help you.
